My TH350 transmission pan has been a challenge to seal. The stock stamped steel pan has raised stiffeners between each bolt hole. Because these stiffeners stop an inch or so from a bolt hole it creates a 2” gap at each bolt hole. Because of the gaps a gasket such as a Lubelocker won’t work. Tried rubber and Right Stuff, then just Right Stuff. I might get it leak free for a week or so, but then the drips start.
Finally broke down and got a cast aluminum pan and a Moroso 93102 gasket, which is a rubber gasket with a steel core. It’s about 3/16” thick so had to grab some longer bolts. The new pan is machined flat, but I went over the gasket surfaces of the pan and transmission with a file to make sure there were no major high spots. Assembled everything and torqued the bolts to 80 in-lbs.
After a week and daily trips it’s leak free so far. Fingers crossed!
