Tank6x2
You’re Awesome Know That!
Lifetime Supporting Member
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Not much going on in my little world, awaiting differential parts, cutting up the floor.. did manage to refurbish the e brake foot pedal assembly
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
50/50 acetone and atf beats Kroil YMMV
I bought some acetone late last year to try this out. I already have the atf. Will try at some future point and report back. I'm very near out of Kroil and have a refillable spray vessel to try it out in, much like the one I use with bulk brake cleaner.
Radiohead
MCMLXXIX
@Radiohead where do you get bulk brake cleaner??
You can get 1 or 5 gallon jug as well as 55 gallon drums at NAPA, O Reilly, probably even Rock Auto. It's out there. I get it in 1 gallon jugs, because it's a lot of money but it seems less expensive than a similar quantity of spray cans. Not as convenient as grabbing a can, but it doesn't take long to fill the vessel and charge with 100# shop air.
Like the hot sauce, I put that [redacted] on everything. It is amazing on insects of all varieties as well as degreasing things it's safe to use on. Especially effective on ants and wasps.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Ahh, brake parts cleaner math, just like toilet paper math.
I have thought about going to bulk, but the math just hasn’t worked out. At Oreilly’s 1 gallon CRC chlorinated is $58.99, or 46¢ per oz. Menards has the big 29oz CRC can for $9.49, or $8.45 after the 11% rebate, bringing to to 32¢/29¢ per oz. The normal 19oz can actually comes in at 28¢/oz right now (after 11% rebate).
Going to 5 gallons does bring the price down to the sub 20¢/oz area, but then I’d have to buy another sure shot type sprayer (lacquer thinner in the current one).
YMMV, I’m sure pricing varies quite a bit depending on region.
I’ve been there and I disagree very much, but it’s great if you wanna peel paint and smell like dead Dino doing it
I've had great luck its been my go to over 30 years since I first read about it and testing in popular mechanics. The acetone thins the oil to allow it to creep in and evaporates to leave an oil lubricant. You have to keep it sealed after mixing and when not in use,so the acetone doesn't evaporate between uses.
Albrigap
South Dakota
Alan
Suburban
1990 GMC R1500 Suburban.
A new pair of 235/75R15 Michelin's on the front of the 4x2.
Computer balance with an alignment.
The alignment guy had quite a fight to get the sleeves to turn to set the tow in.
It just floats down the Maxi Pad now.
Travlr
Central Utah
C
K20 Camper Special
I buy the big cans by the case... but generally use mineral spirits for most things brake cleaner might be used for.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I hate incandescent bulbs...
Fair enough, that's how I feel about LEDs...
While I appreciate LEDs, the problem is everything about these vehicles was designed around incandescent technology. Witness the amount of difficulty and counter-productive Band-Aids like adding resistors that retrofitting ends up causing.
Judge
