What did you fix on your daily, today?
410 John
HdG, Maryland
350 4bbl 4 speed
The shop failed me for my safety inspection. Both engine mounts severely worn. It’s hard to tell the new one from the old one. This is the left side so far. Their full of it! My 2011 Tahoe.
Moderator
They must have a habit of swinging their little weiners around to make them feel important.
Dang brah. I hate these b/s inspections. They always want to stick it to you.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Report them, something :mad:
Tennessee
Replaced the battery on my Tahoe. 12 years was a good run, but theyre $275 now so it got a RK $99 job. We've had good luck with one on the tractor.
Moderator
I haven't had the greatest luck with the RK batteries, but to be fair, I haven't had good luck with ANY battery in the last 10 years. But for what the RK batteries cost, they are still an excellent value compared to other options. I've had them last as little as a year before having issues, but also as long as 6 years.
Tennessee
The last few years I've been hooking a cheap Schumacher automatic maintainer overnight to everything with a battery once in the fall and once in the spring. Seems to do the trick. My square has a 2017 Duralast Gold on it. It'll probably go out now that I've said that lol.
The Right side of Washington
They still do that **** in the rust belt?
Haven’t had a vehicle inspection or emissions test in 30 years out west living in 8 different states. That’s crazy.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
12 years is a very good run, especially for a D T type battery! Over the years working on a utility fleet batteries and tires are the highest cost items with brakes at third place. I'm so old I remember when batteries were shipped dry and the seller or user had to add the acid. I have even had classes on batteries. The D T battery's design can, in some cases, hinder it's performance. I'll shut up about batteries unless someone wants to know more...
Rusty Nail
Cowboy of both Time and Space
your first name only .
350sbc L98
cool thread. a great idea! i like it
i just put a JBL GTO300 and a 12" pioneer IMPP 450 in the Highlander which is about to see 300k on the odo
in a 1.5 foot sealed box
its a fantastic match.
started with a 10 in a bandpass but I found it lacking depth.
next up I bought 2 pairs of ALPINE separates for the doors and a KENWOOD 6404 (4x40)
the rear doors do not have tweeters in them which is good. running tweeters in the backseat draws the soundstage behind you IMO. the plan is 4x6" woofers (with adapters for the back)and 2x1" tweets in the factory position.
ill eat the other tweeters AND the factory CD headunit has a tape deck too! it's staying <3
run the new amp 4ohm stereo, the JBL is R+L-
looks stock,loud AF,crystal clear
:headbang:
JBL,PIONEER,KENWOOD,ALPINE
Rusty Nail
350sbc L98
I want a killer system in at least one of my vehicles.
if you do it you won't be sorry.
I consider myself an audiophile and REALLY get into that stuff. Grew up reading Car Audio and Electronics magazine and spent some time working at a place called Traffic Jams Car Audio when I was a kid. gave every dollar I made back to the owners.
Please be advised, it's a rabbit hole.
My best advice? (about that) is to set a budget and stick to it.
good luck!
What makes a dual terminal battery perform worse and quit working sooner than one with single terminals?
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Since there are two sets of inside terminal strips, less room for electrolyte or plates.
Also important to remember what makes a maintenance free battery. For years the battery plates were mounted in the middle of the case. This was because sometimes the metal moving from plate to plate did not attach and fall to the bottom of the battery. This would short out some plates. When plate design improved, the plates were moved to the bottom of the case. Now the battery has enough electrolyte to last the life of the battery without needing to be serviced.
Any side terminal battery could leak electrolyte too, if not made well or abused.
Last, with a lifetime in vehicle service, for whatever reason I know they don't last as long.
rustyc10_nc
