Vss check engine
Chakoman
Tygh Valley, OR
Harley
Suburban v1500
Just finished a 465/205 swap on my 91 suburban. It was previously equipped with a np241 and electric speedo. The check engine light is flashing constantly throwing a code 24 (vss out of range) Is there a way to make this go away. Thanks for the help.
MrMarty51
Eastern Montana
Martin
Did You install the reluctor wheel from the old TC into the 205 ? If the 205 has the speedo gear then the appropriate reluctor wheel needs to be installed.
Chakoman
Tygh Valley, OR
Harley
Suburban v1500
The 205 looks to have an opening to install a cable speedo. My 91 is apparently driven by a sensor. I dont even need the speedometer, just want to rid the check engine light
Chakoman
Tygh Valley, OR
Harley
Suburban v1500
I see what you are saying. So theoretically i should be able to install the vss into the 205.
willyg
