Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Do you have a power steering pump pulley with two grooves? Usually, there's a belt for Alt, Water Pump, Crank... then a belt for Power Steering and Crank... as well as a belt for AC, Water Pump, Power Steering, and Crank.
The donor truck had a power steering pump pulley with 2 grooves, so i swapped it out as well. I think im only missing the triple groove crank pulley which is on its way. The only thing im not sure of is if the donor truck had an air pump, so im not sure if all my belts are correct, but your info helps alot. Thanks very much! Also I bought the crank pulley that has all three grooves the same diameter 6.6" does this sound correct? Thanks again
Don't worry about the smog pump, it had it's own belt that was driven off yet another groove (but smaller) on the water pump pulley. Having a smog pump doesn't change how the other belts are routed
