1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Still Under Construction
Discussion in '4wd Suburban, Blazer and Jimmy' started by surfridermoflo, Nov 30, 2019.
  1. surfridermoflo
    surfridermoflo Junior Member
    47
    11
    Feb 3, 2018
    Anaheim Hills, Ca
    First Name:
    Ray
    Truck Year:
    Truck Model:
    K5 Silverado
    Engine Size:
    383 Stoker
  2. surfridermoflo
    47
    11
    Feb 3, 2018
    Anaheim Hills, Ca
    First Name:
    Ray
    Truck Year:
    Truck Model:
    K5 Silverado
    Engine Size:
    383 Stoker
    1984 K5 Blazer 350 sbc with stock truck heads, rv cam, stock lifters and rocker arms, stock 350 crank, replaced two-piece rear main seal recently as well as the head gasket, new hei distributor and wires, 4” lift with shackle flip in the rear new shocks and springs in the front, rebuilt and dropped the transfer case an inch to help with the driveline angle, rebuilt 700r4 transmission, installed new exhaust system with long tube headers, 3” pipe to x-pipe to Gibson single chamber(super loud) mufflers. That’s it for now. Gonna update to aluminum heads next as well as install a new floor pan on then driver’s side and inner/outer rocker panels due to rust
  3. akchevrolet
    akchevrolet Full Access Member
    32
    120
    67
    Sep 22, 2016
    First Name:
    Andrew
    Truck Year:
    Truck Model:
    R10
    Engine Size:
    looking good cant wait to get my blazer.
  4. shiftpro
    shiftpro Full Access Member
    3,385
    3,236
    Aug 31, 2012
    BC Canada
    First Name:
    shiftpro
    Truck Year:
    73-87
    Truck Model:
    1500, 2500, 3500
    Engine Size:
    350, 383, 454, 496!
    They say there are a million things to do but that is bullshit. It's only about 100,000 things that need to get finished.
    Overland Suburban and idahovette like this.
  5. idahovette
    idahovette Full Access Member
    71
    1,963
    2,307
    Aug 7, 2016
    Weiser Idaho
    First Name:
    Perry
    Truck Year:
    1975-1979
    Truck Model:
    K20-K10
    Engine Size:
    Give or take!!
  6. Craig Nedrow
    Craig Nedrow Full Access Member
    67
    111
    97
    Sep 1, 2018
    Washington State
    First Name:
    Craig
    Truck Year:
    1973 (have two)
    Truck Model:
    K10 and k20
    Engine Size:
    Have you had the 700r4 in from the get go or was it a swap? Reason is I have a 350/350 now, but almost completed a 454/700r4 combo, and wanted to know if the 350 marriage for transfer will bolt up to the 700r4. Love those K5, had a friend who bought one new in 1973, so had some seat time in a new one.
  7. surfridermoflo
    47
    11
    Feb 3, 2018
    Anaheim Hills, Ca
    First Name:
    Ray
    Truck Year:
    Truck Model:
    K5 Silverado
    Engine Size:
    383 Stoker
    Hey Craig, I’ve had this tranny from the get go. It wouldn’t shift out of 3rd gear so I took it to a local SoCal transmission shop who rebuilt the trans and transfer case. The 350/700r4 marriage feels like a match made in heaven. I’m learning how to mig weld, can’t wait to get the floor pan and rocker panel done!
Share This Page
