1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Stewzer's 1988 Chevrolet R30 Cab and Chassis
Discussion in '2wd Pick-Ups C/R 20 2500 C/R 30 3500' started by Stewzer55, May 5, 2014.
  1. Mr Clean
    Mr Clean Full Access Member
    51
    7,556
    2,477
    First Name:
    Truck Year:
    Truck Model:
    K10 Extra Cab w/ Proper SWB, & 82 2WD Blazer
    Engine Size:
    let me answer that NO!!!!!!!!!!, I can't tell, do you have a bed light? If not, I would take the interior light down, and get a can of the spray foam, and spray it up in there. If you have a bed light, remove it, and you'll get more of the hose in between the two pieces of metal.
    Or you could do like Bucket said, and put a head liner in, and yes it make a big difference.
  2. Stewzer55
    Stewzer55 Full Access Member
    2,235
    35
    Dec 4, 2013
    Ohio
    First Name:
    Stew
    Truck Year:
    1988
    Truck Model:
    R30
    Engine Size:
    I don't have a cargo lamp, sounds like a headliner is gonna be the only option, No big deal though.
  3. Stewzer55
    2,235
    35
    Dec 4, 2013
    Ohio
    First Name:
    Stew
    Truck Year:
    1988
    Truck Model:
    R30
    Engine Size:
    Couple things about this truck, it appears to have the standard gauge cluster used in squares 88-91.
    My next couple days off I'm finally going to have a chance to work on it and get it running, plus with my Uncle in town from San Diego, I've got some good help too. Once I get it started and running up to temperature I'm going to give it an oil change, and change the coolant and hoses, unless its a better idea to change the coolant and hoses before letting it run.
  4. 89Suburban
    89Suburban Full Access Member
    47
    23,096
    1,720
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Good luck bro, I don't think it makes a difference when you do the hoses/coolant. Just don't put off to tomorrow what you can get done today.
  5. Stewzer55
    2,235
    35
    Dec 4, 2013
    Ohio
    First Name:
    Stew
    Truck Year:
    1988
    Truck Model:
    R30
    Engine Size:
    We'll see, tomorrow I may be running all over taking care of errands and there's a high chance of rain too. If its not one thing keeping me off this project its another.
  6. Stewzer55
    2,235
    35
    Dec 4, 2013
    Ohio
    First Name:
    Stew
    Truck Year:
    1988
    Truck Model:
    R30
    Engine Size:
    No pics of what I did today, so text only post. Was trying to get the ignition coil installed back on the intake and I don't have the damn bolts that hold it in place, ANYONE KNOW WHAT SIZE THEY ARE? I looked through an old 89S thread (so old it was with his 89) and it doesn't say anything else except the size of the bolt head. (obligatory pause where I went to the fridge for another beer, no I'm not drunk, I'm just drinkin')
    Also I pulled the passenger side door panel, I think I can safely say that no one else has done that before and lubed up the lock and door striker mechanism.
    Didn't get much done thanks to errands running late. I also got a really late start today too.
  7. 89Suburban
    47
    23,096
    1,720
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    I think they are 5/16" or 3/8" coarse thread bolts there my beer drinking friend.
  8. Stewzer55
    2,235
    35
    Dec 4, 2013
    Ohio
    First Name:
    Stew
    Truck Year:
    1988
    Truck Model:
    R30
    Engine Size:
    Thanks Biff, 5/16 thread, 18 threads per inch (coarse thread). I have to figure out why I have no spark now, there is some damage on the wire going to the coil form the module.
  9. Stewzer55
    2,235
    35
    Dec 4, 2013
    Ohio
    First Name:
    Stew
    Truck Year:
    1988
    Truck Model:
    R30
    Engine Size:
    Okay, I'm gonna run a hot directly from the battery to the coil and see if she'll turn over.
  10. 89Suburban
    47
    23,096
    1,720
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Any luck?
  11. Stewzer55
    2,235
    35
    Dec 4, 2013
    Ohio
    First Name:
    Stew
    Truck Year:
    1988
    Truck Model:
    R30
    Engine Size:
    The wire I ran from the battery to the coil acted like the key was switched on. Fuel pump kicked on. No spark, no injector pulse. I wonder if the coil took a shit or the distributor is bad. Ignition module is good, I did test the coil before I installed it last summer. I nearly pulled the coil off of my Olds and put it on there, but the bolt on the right side of the coil is hard to reach with a B-body distributor, they're special due to the windshield cowl. I'm about to say fuggit and put a carbed 454 in there with a fuel pressure regulator to keep the electric pump.
  12. bucket
    bucket Super Moderator Staff Member
    39
    23,447
    10,072
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Does the check engine light come on when you turn the key on? If it does, you might just have a bad pickup coil.
    Snoots likes this.
  13. Stewzer55
    2,235
    35
    Dec 4, 2013
    Ohio
    First Name:
    Stew
    Truck Year:
    1988
    Truck Model:
    R30
    Engine Size:
    Small bump. I really hope to get this thing running again this year.
  14. Stewzer55
    2,235
    35
    Dec 4, 2013
    Ohio
    First Name:
    Stew
    Truck Year:
    1988
    Truck Model:
    R30
    Engine Size:
    Finally bought a distributor, It's stabbed in, taking a break for dinner and then gonna head back out.
    I miss you fuggers around here...
  15. bucket
    39
    23,447
    10,072
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    :wave:Look who's back!
Share This Page
