Speedometer Drive Gear Color/Teeth
custodian
Catawba
William
C10,
5.3 LS, 5.3LS
I just finished my LS swap in the 85 C10 using a 350 turbo trans. I drove it and the speedometer is extremely high. It currently has natural gear, I think that's the color, with 19 teeth. My tire size is 255/75/15 with about a 28.9" height. I need to know what color speedometer drive gear do I need for the transmission with a 3:08 gear rear end? Any help would be greatly appreciated. I know there's calculators out there to determine using tire size.
Supporting Member Army
You need to know how far off it actually is. Go for a drive, record the speedometer speed shown and the GPS speed from your phone at several easy spots like 10,25,50mph. They will have a percentage difference that they are off at all speeds. Then you just need to pick the gear that is that percentage different from the one you have. You should also look at what drive gear you have as well. Pair drive and driven to get a ratio.
What drive gear does it have? That natural is the driven gear. Most calculators will want to know drive gear size, gear ratio, and tire size to then give you a driven gear size.
https://www.tciauto.com/speedometer...LDK5eOkqWO2bMgJKsexWEdgEqu_2c_zKX8WLYL-U4#350
custodian
Catawba
William
C10,
5.3 LS, 5.3LS
I have no idea what the color of the drive gear is. I did drive it and it read about 40mph to fast, not kidding.
Order gears for a 1984 C10 TH350 with a 3.08 rearend. 8 tooth and 20 tooth .
What I've always done andbits always worked close enough for government work. I buy what the dealer says came factory in a similiar combination. Example if I were running a th350 with a 3.73 gears and A tire comparable to a GM Gbody performance model. I'd go to the dealer and order both speedo gears for a 1984 Monte Carlo SS with a th350 and a 3.73 gears. I always end up with a reasonable accurate speedo.
Your case I looked up a 1984 C10 Th350 3.08 gears,factory tires should have been between 28"" and 29" so factory gears should work . According to the internet that would have been 8 tooth and 20 tooth. Factory speedo gears were always close enough when someone went a little larger,factory tires wore down etc. Check what the dealer says as far as 8 an 20 being stock.
You should be able to see the drive gear if you got the driven gear out?!?!? Colors are listed on the link I posted.
If you have a 19 or 20 gear drive gear.. it calls for a 39 driven gear with your tire and rear end ratio. 40mph too fast at what speed? If you were going 40 and it read 80... then it sounds like you probably have a 19 drive gear(yellow) or 20(brown) to go with that 19 driven gear. Going to a 39 will give you a 50% reduction in displayed speed in relation to actual speed.
custodian
Catawba
William
C10,
5.3 LS, 5.3LS
Yes, going about 40mph and the speedometer was reading near 80mph. I'll take the driven gear out this weekend and look and see what color the drive gear is.
custodian
Catawba
William
C10,
5.3 LS, 5.3LS
I got around today to take a look at the drive gear that's in my 350th. This is the best picture I could get. I'm still not sure what color it is. I'm I right in counting the groves to get the tooth count?
79TanSquare
