Selector valve help
86k20-ds
arizona
geoff
K20 Custom Deluxe
5.7 Liter 350
I have had to replace the selector valve in my 1986 k20 (carbureted 350) and the replacement Acdelco unit I ordered has 5/16” return lines but my metal hard lines are 1/4”. I tried to use adapters but they did not work, and somehow in the process I broke a barb off the selector valve. Anybody know where and if I can find one with 1/4” return barbs?
Thanks
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
I took the 1/4 " hose and with help from a needle nose plier enlarged it enough to fit the 5/16" line. A little twisting action, a little heat gun help, made it work.
You will probably need another selector valve now.
awar
K35
5/16” return is what I am using on my three tank crew cab.
doo-daa
