JBswth
- Jan 24, 2022
- Vallejo, California
- James
- C25
- 292 cubic inches
Just put new rings on my 73 GMC C2500 with 292 6 cylinder. It fought me every step of the way - chain auto parts store gave me the wrong rod bearings, (they ordered them from their warehouse), then they give me the wrong rings, again ordered them through the warehouse. Then, after buttoning everything back up, the engine seemed locked solid. The oil ring on piston #6 was the wrong one - too thick for the groove. That's what I get for trying to race against the coming sunset. Didn't notice that the oil ring was stuck solid in it's groove, then, after replacing it with one of the old rings that looked good, engine still wasn't right - too hard to turn. The rod bearing shells on #6 were made wrong. With the cap bolts loosened, engine turned fine, so I wound up using one of the old shell halves that still looked good. Engine now turned fairly easily. Then battery, which was fine with the old worn rings, was too weak for an engine with good compression. Then, with the #6 rings and bearings problem solved, and a new battery and clean plugs, it ROARED to life. Let it run for an hour in my back yard. Will change the oil - I had to hone the cylinders, so I have to make sure no grindings and grit are swimming around in the oil - then ROAD TEST!
J. B.
J. B.
