1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
rag joint replacement
Discussion in '2wd Suburban, Blazer and Jimmy' started by Tobe's84Jimmy, Oct 16, 2017.
  1. Tobe's84Jimmy
    Tobe's84Jimmy Full Access Member
    46
    59
    37
    Jul 29, 2016
    Seattle
    First Name:
    Tobe
    Truck Year:
    Truck Model:
    Jimmy Sierra Classic
    Engine Size:
    5.7 350
    the steering is much better now. the old one was well overdue for replacement, just didnt cross my mind when i did the tie rod ends and bar, pitman arm, steering gear, steering stabilizer and drag link. i mean of course all that stuff helped but this was the 'aha' part. granted, its not perfect steering but for a 33yr old its really nice steering!
    74 Shortbed likes this.
  2. CSFJ
    CSFJ ----------------- Supporting Member
    6,112
    4,908
    Jul 1, 2014
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    You should check out the Cherokee steering shaft mod. There should be a thread or three in the steering suspension section of the forum detailing it.
    Tobe's84Jimmy and Honky Kong jr like this.
  3. Honky Kong jr
    Honky Kong jr Super Sarcastic Man
    48
    14,922
    9,441
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    What he said
    Tobe's84Jimmy likes this.
  4. Tobe's84Jimmy
    46
    59
    37
    Jul 29, 2016
    Seattle
    First Name:
    Tobe
    Truck Year:
    Truck Model:
    Engine Size:
    5.7 350
    hi CSFJ, hey Honky Kong Jr. i did see that for the swap, it just looked like way more work than keepin stock, and i just wanted to see how much better it would get like this. thanks for the suggestion though⏹
  5. Camar068
    Camar068 Supporting Member Supporting Member
    2,402
    698
    Feb 5, 2014
    Kentucky
    First Name:
    Truck Year:
    Truck Model:
    K10/LM7 5.3/4L60e/np208/3.73/31"
    Engine Size:
    10 yrs Air Force
    10 minutes removal of part at the yard, 30 minutes tops installing. Can't beat $15 for less play. No offense intended, had the same train of thought as you when I went to swap my rag joint.
    Honky Kong jr likes this.
  6. Honky Kong jr
    48
    14,922
    9,441
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    What he said. Easiest way to get them off the Jeep is pull the 3 steering box bolts and let it hang.
  7. Honky Kong jr
    48
    14,922
    9,441
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    IMG_0323.JPG Easy peasy
  8. CCSS
    CCSS Full Access Member
    101
    27
    Nov 29, 2013
    Morristown, Tn
    First Name:
    Daniel
    Truck Year:
    1985 & 1986
    Truck Model:
    C10 & K5
    Engine Size:
    4.3 & 5.7
    I have been trying to decide rag joint or Cherokee. I think I will look for the Cherokee parts since I am stuck in Knox and there's a pull a part here. If I don't find one may do the rag joint.
  9. 4WDKC
    4WDKC Full Access Member
    2,365
    1,071
    Jan 27, 2016
    Southern Florida
    First Name:
    Kacy
    Truck Year:
    Truck Model:
    Engine Size:
    I put mine on with both bolts accessible from the top, any reason for installing this way?
  10. Honky Kong jr
    48
    14,922
    9,441
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    The way mine is was where the wheels were straight an the steering wheel is too. As long as you can everything to line up it shouldn’t matter. As far as I see it.
Share This Page
