Radiator Support Bushings: Is this correct?
Toad455
North Texas
Kevin
Hello All. I have a set of Energy Suspension cab and radiator support bushings # 4109G. The cab bushings fit but the support bushings seem to be wrong. See the pics. The hole in the frame is quite a bit larger than the center of the bushing. The support can slide around quite a bit. I haven't tightened it down all the way but I feel that even tight it will be able to slide. The truck is a 78 2wd. Anyone used these before with success?
the
Sad Sack
Nebraska
Goober
C15
I came up with these:
Look diff than what you are showing.
Don't even see Energy Suspension support mounts on their site alone just the body mount kit.
nvrenuf
Mobile, Al.
What’s the complete kit part number?
legopnuematic
Licensed Junk Dealer
MO
Spencer
straydog371
Army Law Enforcement Supporting Member
WNY
Kerry
legopnuematic
MO
Spencer
I can measure on my 79 when I get a chance, I am using energy suspension body mounts.
To hold us over until then, here is an old photo of my 79s frame.
Toad455
North Texas
Kevin
They came in the
I bought the whole kit for cab and support at Summit Racing part number ENS-3-4109G. The do look different for sure.
Toad455
North Texas
Kevin
That area at the left arrow fits very loose in the hole. And is does look enlarged but my dad bought the truck new and it's never been apart till now. There is a fair amount of rust pitting, I wonder if the hole is enlarged due to rust? I didn't pay attention to the hole size til now.
Toad455
North Texas
Kevin
Not certain, but it appears the holes have been slightly enlarged by someone?
I bought a set from LMC when I replaced mine:
https://www.lmctruck.com/body-components/body-mounting/cc-1973-87-polyurethane-cab-mount-bushing-set
@legopnuematic was typing same time as me and has the likely solution.
Good luck!
Thanks for the reply. They do look enlarged, if they are it has to be from rust, we've had the truck since new and it's never been apart til now. If I just tighten the dog out of them I guess it'll keep it from skating from side to side. Not sure why all my replies don't show in the right place.
Sad Sack
Nebraska
Goober
C15
@TotalyHucked
Hey sir, what is the inner diameter of the body mount hole in part number
Part# 349-4073-3​
Sad Sack
Nebraska
Goober
C15
This is what USA1 shows as well:
Similar to the Summit Part Number: SUM-RP24635
Doesn't look like the Energy Suspension parts...
@TotalyHucked
Part# 349-4073-3​
ID is right about 2 5/8"
Toad455
North Texas
Kevin
@TotalyHucked
Part# 349-4073-3​
The hole in my frame mount is roughly 1.720, varies a little since the rust made it out of round a bit. Here's pic of the size of the part of the bushing that fits in the hole. There's about .350 difference
crowe-t
