Radiator Replacement
CopperPennyNickel
Steve Darnell
I am getting ready to replace my radiator on the truck I just got. I realized the coolant was low and topped it off and now understand why it was low. The truck does not have a heater in it and the heater core lines have been bypassed. So once I put in the new radiator and fill it up, how do I burp the system with no heater to run. Everything I have looked at online says you must run the heater on high. I don't even think the heater controls do anything. I have never replaced a radiator before. Anything to add to these steps?
Drain radiator with petcock, make huge mess, clean up, then proceed.
Take out radiator disconnect hoses
Put in new radiator connect new hoses and put fan shroud and fan back in place
Fill new radiator up with coolant to bottom of neck filler
Then what?
82SquareBurb
Soddy Daisy TN
Derek
I would just fill with 50/50 coolant and distilled water then run it to temp, then top off as needed should be fine. Since there is no heater there is no air to purge if the hoses are looped or blocked off.
Remember to make sure the coolant drains all over the floor, and misses the bucket to meet specs.
rancher1913
Colorado
brian
c10, k5, k30
you can pull a vaccuum on it after filling, thats what we do with heavy equipment
Scott91370
Burleson, Tx
Scott
Sierra1500
Vacuum is the best but you can park it with the radiator fill uphill (highest point) - not 100% but it helps.
Don't overthink it. I just removed my HVAC/heater core from my truck to clear the new SloshTubz, looped the heater hoses onto the water pump. I just jacked the pass side of the nose up high enough to guarantee the inlet was the highest point. Let the truck get up to temp, rev it lightly up to 1500-2000 and hold it steady for a few seconds, moving the water faster can help clear bubbles/pockets. Do that a couple times, keep checking it and topping up as needed.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Then what?
Sounds like a pretty solid plan, I usually just pull the bottom hose to drain since the petcocks are often damaged, stripped or just plain slow.
There is a difference between blocking the heater hoses and looping the heater hoses. You want them looped not blocked for most intake manifolds. By looping the heater hoses, the rear cylinders can bypass back to the radiator. Factory many chevrolet applications used the heater core as that bypass. As long as your hoses are looped,your engine sees that the same as max heat for bleeding purposes. A couple more tricks for bleeding. If you have a sensor high in the intake manifold cooling passage,remove it and fill through the radiator until coolant comes out of the sensor hole,that means all air below that point is gone. Another trick,wedge the thermostat open with an aspirin. Then fill the system,the aspirin will allow the system to fill and bleed like an open thermostat then dissolve,you can also put a tiny hole in the sealing disc of the thermostat,so it can't air lock and can bleed cold.
WFO
Texas Panhandle
That sounds right for a 5.3, but I've never had to do any of that on a small or big block.
So, you don't have a heater anymore?
82SquareBurb
Soddy Daisy TN
Derek
Trapped air in a small/big block Chevy is not really a thing unless it has a divorced fill/water neck since that is the highest point where the air would go just idling. Should be good to just idle it out.
I should've put in there, wherever you're filling from just needs to be the highest point. Some vehicles it's one of the top corners of the rad, some it's not.
I don't have anything at the moment, no AC, no heat, no nothin' lol. Planning on Vintage Air next year
  • Like
Reactions: WFO
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
Those older vehicle were not really a problem with bleeding. To make it easier make sure to use a thermostat with a jiggle pin or just drill an 1/8" hole in it.
doo-daa
