Preformed hoses
Raybob9289
Littleton
Raybob
Cheyenne 30
Does anybody have a source for preformed hoses?
My 454 (now K30) has the outside of the frame fuel line and the 3/8" preformed
over the frame hose is dry rotted. I suppose I could use just bulk fuel line but the bends are funky.
I also need to replace the power steering 3/4" reservoir hose.
Thanks...
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
I had an issue with my '85 K30. I couldn't find a replacement. As you can see from the pictures there are multiple bends. I ended up using a part from Eckler's Corvette
GM 3994298; Eckler’s 6271610 - 1970-81 Corvette Formed “S” Hose (Frame Fuel Line to Fuel Pump) Photo #2.
To get the angles right I had to cut the "S" pipe in the middle and add a short piece of metal fuel line. Unfortunately I didn't take picture once I finished.
If you have the remote P/S like mine (picture #3), the part number is GM 14040767. Good luck finding one. I think I bought the last one a couple years ago. I originally used 3/4" hose, but it kinked the hose a little.
Memaloose
Dolan Springs, AZ
Tony
That's a crazy looking preformed fuel hose, good luck!
If you're good with tube bending, make a metal one.
