Oil leaks
CWBlack71
Del Rio, Texas
K30 Scottsdale
Gentlemen, I have been chasing an oil leak on a 86 350. I have replaced the rear main seal, oil pan gasket and the intake gasket. I have also replaced the dipstick tube just in case. Still have a leak somewhere and not sure where to go from here. The oil seems to be coming from the passenger side around the starter location. Any ideas or suggestions?
CWBlack71
Del Rio, Texas
K30 Scottsdale
I did replace the valve cover gasket and I did put a new distributor gasket.
Grumpy
Saskatchewan
Daryl
Some small block Chevys in that year of manufacture range actually had a factory bolt-on kit that would place the engine oil dipstick on the passenger-side of the block. This was only on the late blocks with a two-piece rear main seal. It would be located near the oil pan rail and was secured with two cap screws.
I have seen leaks from there on only a few occasions.
CWBlack71
Del Rio, Texas
K30 Scottsdale
This one has the dip stick on the passenger side, but it is pressed in
Shorty81
Baby Boomer
North West ohio
Darren
Check your positive crankcase vent (PCV stick) in your valve cover and make sure it's good. Might have a pressurized engine.
CWBlack71
Del Rio, Texas
K30 Scottsdale
Could it be a head gasket? Could it be a crack in the block? If so, wouldn’t either of these cause other problems with the way the truck runs?
CWBlack71
Del Rio, Texas
K30 Scottsdale
The pvc valve is not clogged up. I can blow thru it. It seems good
CWBlack71
Del Rio, Texas
K30 Scottsdale
I have looked at that and it is clean and dry
Is yours a that or is yours a those? Some have a sender or switch behind the distributor and some have a second switch on the block.
CWBlack71
Del Rio, Texas
K30 Scottsdale
Mine is behind the distributor.
Does yours have 2? Some have 2 reread #11
CWBlack71
Del Rio, Texas
K30 Scottsdale
It is screwed in to the block behind the distributor
Does your truck have 2. One on the side of the block and one behind the distributor. A lot of trucks have 2. Which is why I keep asking if it has 2
Linemanjl
