nss/reverse light switch
Donato
Barstow CA
Don
chevy c-10
I was having problems changing this switch that is located at the bottom of steering column on a 69 chevy c10 To get to the two screws that hold the switch on column you just about have to drop the column. Once you get it off and realigned the switch put a16 gauge wire in the right hole then fold it over the top of switch and wind it around connection spades. Do not try to use the small installation screw just go buy a 2 inch hose clam and use it to install the switch. After two days of trying to use the screws the hose clamp works great.
Laqota
