1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
New to me 85 C20 C6P
Discussion in '2wd Pick-Ups C/R 20 2500 C/R 30 3500' started by Jim Hensley, Feb 17, 2016.
  1. Jim Hensley
    Jim Hensley Member
    49
    37
    10
    Feb 14, 2016
    First Name:
    Shannon
    Truck Year:
    Truck Model:
    Engine Size:
    My latest......Picked this up the other day for a steal, It was so clean I couldn't pass it up, its a C20 with the C6P Heavy duty Chassis package and is a Silverado Package. 350 th400 interestingly enough this can hold a bigger camper than the dually but just 100 lbs less weight . I went and looked at it and it wouldn't hardly run, y pipe is broken and held together with a tin can and a worm clamp , I managed to drive it home 25 miles at 65-70 mph got it home and tinkered with it to find out its got a big vac leak under the carb adapter , the dist was super loose, it is in sad shape. The ad said it had a rebuilt engine with 1000 miles ,, needless to say when i asked the guy about it he couldn't seem to locate the paperwork ..lol I could see by the 2 inches thick of grease on the block it wasn't rebuilt but did seem to run OK on the highway.
    Little cleaning up..
    OK got the exhaust redone the other day , The Original was broken right after the Y on the Y pipe, They had it wrapped up with muffler putty and tin flashing and worm clamps..lol
    I just had em replace it from there back with a flowmaster knockoff Xcelerator Muffler Hate flowmaster , but this was kinda heavy duty and its not a racecar after all.
    I found a used bolt on tip out in the scrap pile.. so I asked what he wanted for it and He gave it to me for free.
    Also pushed out some of the damaged rear lower quarter.
    Also I knew it leaked from the exhaust manifolds, and turned out the block is a 300 hp 350 from a 70 impala with a set of 73 993 heads, old style understyle manifolds they tried to bolt up to the 85 y pipe . They had packed the flanges with muffler putty to try and stop the leaking, but it didn't work, still sounds like at idle but the main system is now OK , debating headers or just get the correct manifolds.
  2. Jim Hensley
    Jim Hensley Member
    49
    37
    10
    Feb 14, 2016
    First Name:
    Shannon
    Truck Year:
    Truck Model:
    Engine Size:
    Took the seat and carpet out yesterday, it was so nasty I couldn't stand riding in it until I get it redone..
    Gotta love texas trucks..
    Heater core had been leaking for sometime I guess,
    just sprayed down the carpet to get most of the funk out till I can clean the floor off and coat it and add some dynomat and install new padding and carpet and different seats.
    I go to school full time so I need to drive it 4 days a week.
    damn sure smells better .
  3. Old77
    Old77 Super Moderator Staff Member
    26,855
    4,363
    First Name:
    Truck Year:
    1977/1991
    Truck Model:
    C10 longbed/R3500 Dually
    Engine Size:
    350/454
    Nice progress on the clean up :waytogo:
  4. Jim Hensley
    Jim Hensley Member
    49
    37
    10
    Feb 14, 2016
    First Name:
    Shannon
    Truck Year:
    Truck Model:
    Engine Size:
    Thanks I almost bought a c20 sub close to the same as yours..
  5. Old77
    26,855
    4,363
    First Name:
    Truck Year:
    1977/1991
    Truck Model:
    Engine Size:
    350/454
    With the big block they definitely got the power to what what you want. Looking underneath yours looks about as rust free as mine, too :) That truck is looking super solid all around
  6. Jim Hensley
    Jim Hensley Member
    49
    37
    10
    Feb 14, 2016
    First Name:
    Shannon
    Truck Year:
    Truck Model:
    Engine Size:
    yea Mines rocking a 300hp 350 short block from a 70 impala according to the index code and some 73 993 heads , it runs like crap at the moment but I eventually want to do a vortec 350/4l80E swap if the IRS would let go of my money...
  7. Half Assed
    Half Assed Full Access Member
    116
    6
    Oct 31, 2015
    SARASOTA
    First Name:
    D
    Truck Year:
    1987, 1988
    Truck Model:
    R20 3+3, V20 Suburban
    Engine Size:
    'bout tree fiddy
    Heavy duty chassis but doesn't have a full float rear axle. I'm not that familiar with the RPO codes/packages though...
  8. Stewzer55
    Stewzer55 Full Access Member
    2,235
    35
    Dec 4, 2013
    Ohio
    First Name:
    Stew
    Truck Year:
    1988
    Truck Model:
    R30
    Engine Size:
    I think it might have more to do with the brakes and springs rather than the axle.
    Love the color of the truck, looks like it's going to be a great project.
  9. Jim Hensley
    Jim Hensley Member
    49
    37
    10
    Feb 14, 2016
    First Name:
    Shannon
    Truck Year:
    Truck Model:
    Engine Size:
    Brakes , Springs and the frame is thicker, Its kind of In between a 3/4 ton and a 1 ton..
    Reg 3/4 frame is 3.57 wide and the C6P is 4.53 and the crew cab 1 ton is 7.33 and the reg cab 1 ton is 6.14 thick . C6P rear springs are rated 1,000 lbs more than a reg cab 3/4 ton. the the 1 tons and crew cab 3/4 crew cabs only got full floaters 6,000 lb vs 7500lb for a full floater. according to the manual..lol You could still check the boxes and order what you wanted back then though, not like today.
  10. Jim Hensley
    Jim Hensley Member
    49
    37
    10
    Feb 14, 2016
    First Name:
    Shannon
    Truck Year:
    Truck Model:
    Engine Size:
    Painted the roof and removed the running boards.
  11. Stewzer55
    2,235
    35
    Dec 4, 2013
    Ohio
    First Name:
    Stew
    Truck Year:
    1988
    Truck Model:
    R30
    Engine Size:
    Huge difference losing the running boards, looks so much better now.
  12. Jim Hensley
    Jim Hensley Member
    49
    37
    10
    Feb 14, 2016
    First Name:
    Shannon
    Truck Year:
    Truck Model:
    Engine Size:
    Better pics with my good camera ordered a new summit racing street 600 cfm strip carb Saturday.
  13. Jim Hensley
    Jim Hensley Member
    49
    37
    10
    Feb 14, 2016
    First Name:
    Shannon
    Truck Year:
    Truck Model:
    Engine Size:
    well Little update I did a compression test and 7 re around 150 and #8 is 50 LBS wet or dry and the exhaust it pulling a peice of paper in so I suspect it has a burnt valve. I picked up a running LO5 from a 90 van for 400 bucks fan to flywheel and will be swapping that out during spring break.
  14. bigcountry78
    bigcountry78 Supporting Member Supporting Member
    2,946
    6,199
    Apr 16, 2013
    Hickory, North Carolina
    First Name:
    James
    Truck Year:
    Truck Model:
    K10 Custom Deluxe
    Engine Size:
    That's a pretty clean truck, nice score. I really don't see how those running boards ever caught on. I mean I like old school stuff, but man I hate those things.
  15. Jim Hensley
    Jim Hensley Member
    49
    37
    10
    Feb 14, 2016
    First Name:
    Shannon
    Truck Year:
    Truck Model:
    Engine Size:
    Well she was traded for this 84 GMC c1500 high Sierra
    I'll start a new thread for it
Share This Page
