New daily driver
Moderator Administrator
I know it's spendy but from just the info you've shared, I think the best route is the 3rd option. I hate the saying cuz it's not always true but "you get what you pay for" and if he's got that good of a reputation it's for a good reason. Would be a tough pill to swallow for the ol' checkbook, though.
If you haven't made a decision yet, I'd throw out my buddy Eric Evans from Queen City Speed here in Gainesville, Ga. It'd be worth reaching out at least, he tunes just about anything and really knows his stuff. He gets flown all over the country and used to work for Detroit Speed, he's now a full machine shop as well. He'll do in person, remote tuning or may come to you as well if he has time. Super good dude
bluex
Spartanburg SC
C15
I had called an emailed the middle shop this morning but still haven't heard back.
I did get the vvt information from FRP this morning though which is one thing I was struggling with figuring out. I still dont understand how they got the numbers but it's their cam an they did the testing so no reason not to believe them.
Besides that I think I can probably do the rest honestly. Its basically just driving it, plugging the numbers in an driving it some more. I've found enough dodge specific info that it might take me a bit but I'll probably try it myself first. I've got to buy the credits regardless so its worth a shot I think.
Yeah if you've done some other tuning I don't see why you can't take a crack at it
That's one thing I haven't dipped my toe into yet, tuning anything
bluex
Spartanburg SC
C15
Decided on going with the middle shop after all, figuring theyd get it pretty close an I could dial it in perfect after I ran out of time with them.
They lock their tunes :banghead: an that means I'm stuck with them or start over from scratch. Wish they would have gave me that tidbit of info up front. Loaded the "startup" tune this morning. Still won't idle on its own am waiting on a reply. This was my worry on remote, up to 24 hrs alloted for a response, an its Friday so nothing on the weekends probably....
bluex
Spartanburg SC
C15
Got a response that I more than likely had a pushrod out of position or another problem with a valve sticking. I was like theres no way I checked those dumb things 3 times each. Well I had one still under the rocker but not fully in it's cup. :doh2:
Apparently really common issue on these engines, unfortunately it cost me another set of valve cover gaskets to find. It will idle on its own for a bit but then eventually dies still. Sent them another log but dont think ill hear back now till Monday.
bluex
Spartanburg SC
C15
Still not going well, it idles but makes nearly no vacuum. Setting a cam/crank code that it shouldn't be also. They are about to tell to me I've got to pull the thing apart an check that the cam is timed correctly. The machine shop did that part so I have my doubts, even though hes sure its right. I put the limiter in the Phaser though so if thats messed up it's on me again.
I'm not even excited about it anymore now. It was freaking awesome last night when it settled into a nice idle on its own an I was stoked. Now I hope to walk outside in the morning an it just be gone :bawl:
Oh man, I hate that. Keep pushing though, it will absolutely be worth it in the end, no matter the frustration now.
bluex
Spartanburg SC
C15
Yep -30.5 deg on the difference between the cam an crank. Sent them that info but I'm sure thats to much so it's coming apart. Hopefully I can do it without having to pull the heads or the whole engine back out. Its still alot of work either way so I'm gonna be taking a break on it as I have a side job lined up next week then I'll be on vacation.
I was looking at how to line everything up on it timing wise an realized that I was supposed to get a limiter for my VVT phaser because of the bigger cam. Im pretty sure they sent me a lockout instead. The lockout is bigger an has a set screw you put in the middle to wedge it in there an I remember putting that in before buttoning up the cover. Guess I'll be checking that too as you get a little better throttle response an power with the limiter so you can get some vvt action from it.
So long story short, its obviously cursed lol
MoGold
