1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
My daughter's 81 Blazer
Discussion in '2wd Suburban, Blazer and Jimmy' started by sactodreamer, Nov 25, 2018.
  1. sactodreamer
    sactodreamer Junior Member
    Nov 25, 2018
    Sacramento, CA
    First Name:
    Ron
    Truck Year:
    Truck Model:
    Blazer
    Engine Size:
    We're about to pick up this 81 Blazer from as a lien sale . The body looks really straight except for the sunroof and roof around it (dented). There are a lot of new parts on the 305 but it doesn't turn over. I'm thinking the engine is seized up
    I'm expecting to do a lot of searches here to figure this thing figured out.
    I don't know much about the square body blazers, is there anything I should be looking for on it?
  2. animal
    animal Super Moderator Staff Member
    50
    3,932
    1,253
    First Name:
    Lee
    Truck Year:
    Truck Model:
    c10 silverado
    Engine Size:
    350ish
    Cool project :waytogo:
  3. Big Chip
    Big Chip Full Access Member
    52
    3,889
    5,265
    Oct 19, 2017
    Michigan
    First Name:
    Kevin
    Truck Year:
    Truck Model:
    C35
    Engine Size:
    I would love to have a 2wd Blazer. Nice find.
  4. Charlie
    Charlie Mopar by Birth. Chevy by Choice.
    1,740
    775
    Aug 2, 2017
    Euless, Texas
    First Name:
    Don
    Truck Year:
    Truck Model:
    Cheyenne 10 LWB
    Engine Size:
    350/TH350/AC/4 BBL Quadrajet
    :welcome:
  5. Old77
    Old77 Super Moderator Staff Member
    26,519
    3,629
    First Name:
    Truck Year:
    1977/1991
    Truck Model:
    C10 longbed/R3500 Dually
    Engine Size:
    350/454
    Cool!! Love the 2wd blazers!!!
  6. HotRodPC
    HotRodPC Administrator Staff Member
    45,398
    5,640
    First Name:
    Truck Year:
    85 K20 LWB / 86 K5
    Truck Model:
    Silverado / Silverado
    Engine Size:
    454 - Turbo 400 - 3.73 350 - 700R4 - 4.10
    Ahhhh how terrible that the Wee O Five is locked up. Just gonna have to swap it out for a Three Fitty !!! How Terrible... said noone ever.
  7. roundhouse
    roundhouse Full Access Member
    669
    514
    Apr 5, 2014
    atlanta ga
    First Name:
    justin
    Truck Year:
    77,78,79,80 ?
    Truck Model:
    Engine Size:
    Doesn’t turn over with the starter ?
    Make sure the starter is working
    Check that the relay is getting power from the ignition switch
    Checkthat the main power wire to the starter is good and has good connections
    If that is all good
    Remove it and bench test it with some jumper cables
    doesn’t turn over with the belts loose or removed (a locked alternator , ps pump or water pump will keep an engine from turning over )
    Remove the spark plugs and belts and try a socket on the crankshaft
    Snoots likes this.
  8. Snoots
    Snoots Supporting Member Supporting Member
    4,808
    6,418
    Jan 23, 2013
    First Name:
    Roger
    Truck Year:
    Truck Model:
    Jimmy Sierra
    Engine Size:
    I'm certain HonkyKongJr would chime in, BIG BLOCK!
  9. Craig 85
    Craig 85 Full Access Member
    2,564
    1,934
    Jan 25, 2017
    Grass Valley, CA
    First Name:
    Craig
    Truck Year:
    Truck Model:
    K30 SRW
    Engine Size:
    454/TH-400/NP205
    Nice project.
Share This Page
