1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
My 88 C3500 3+3
Discussion in '2wd Pick-Ups C/R 20 2500 C/R 30 3500' started by Stumpuller6.5, Apr 30, 2012.
  1. Stumpuller6.5
    Stumpuller6.5 Full Access Member
    94
    Mar 30, 2012
    CANADA
    First Name:
    Clancy
    Truck Year:
    1988
    Truck Model:
    C3500 3+3 Long Box Dually
    Engine Size:
    6.5 Turbo Diesel/SM465/D70
    Well here are some pictures, its still not in my yard yet, but as soon as a I have a few open days I will go pickup this huuuuge biotch! :cool:
    It had an attempted theft prior to going up for sale, so there are a few things to fix, (drivers window and related wiring, plus ignition switch) And the PO figures it needs a tuneup. Well I got it for the body mostly, I do plan to, if it can handle it, get it running smooth and just use it for now. :thumbs:
    This project if it comes to be what I plan, will not be finished this year but take some time to complete, as $$$ allow. :D
    So as it sits, it has a newer 6.5 turbo diesel (with 100,000miles on it), a SM465 4 speed manual trans and I assume a 14Bolt FF out back. (have yet to confirm this.)
    I plan to restore and install a dana 60 front, duramax/allison/to be determined t-case, and definatley some rickson 19.5s :)
  2. bucket
    bucket Super Moderator Staff Member
    39
    23,442
    10,061
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    I think you picked a winner! The rear is a D70, by the way. The only squarebody duallies with a 14FF were the Cab&Chassis models.
  3. Old77
    Old77 Super Moderator Staff Member
    26,855
    4,363
    First Name:
    Truck Year:
    1977/1991
    Truck Model:
    C10 longbed/R3500 Dually
    Engine Size:
    350/454
    Solid body on that one for sure!
  4. Stumpuller6.5
    94
    Mar 30, 2012
    CANADA
    First Name:
    Clancy
    Truck Year:
    1988
    Truck Model:
    Engine Size:
    Good to know! Thanks! :favorites13:
  5. Stumpuller6.5
    94
    Mar 30, 2012
    CANADA
    First Name:
    Clancy
    Truck Year:
    1988
    Truck Model:
    Engine Size:
    Well after a month or so I finally have time to go pick it up, gonna trailer it home. :)
    Excited!
  6. wildcatjason
    wildcatjason Full Access Member
    513
    Apr 7, 2012
    Kansas
    First Name:
    Jason
    Truck Year:
    1988
    Truck Model:
    suburban
    Engine Size:
    cummins 3.9 4bt
    I like that. If that 6.5 runs well I'd leave it be unless you 6.6 sitting around.
  7. elstm3
    elstm3 Full Access Member
    31
    130
    Feb 9, 2012
    montana
    First Name:
    lynn
    Truck Year:
    88
    Truck Model:
    V30 crew cab dually
    Engine Size:
    6.2 twin turbo diesel
    So Stumpuller6.2 your looking to convert you 1 Ton crew cab to a 4x4 as well then? Ill be sure to take lots of pictures and do a decent write up with all kinds of measurements and ect. I already have the front suspension parts but an 8 lug axle to get started with finding the location of all the brackets and ect.
  8. Stumpuller6.5
    94
    Mar 30, 2012
    CANADA
    First Name:
    Clancy
    Truck Year:
    1988
    Truck Model:
    Engine Size:
    First thing I`m going to do is flush ALL the fluids engine,trans,diff,coolant,ps,brakes. then get a compression test done to make my decision on were to go with it. :)
    Excellent! i have a parts truck lined up aswell. are you going to do the front clip or just cut crosmember and do the brackets etc? I was kind of inclinded to do a clip swap, granted it even feasable....
  9. elstm3
    31
    130
    Feb 9, 2012
    montana
    First Name:
    lynn
    Truck Year:
    88
    Truck Model:
    V30 crew cab dually
    Engine Size:
    I have the whole front frame clip from a blazer but i am just going to use it for the location of the bolt holes and mount all the brackets and cross member onto my frame.
  10. Stumpuller6.5
    94
    Mar 30, 2012
    CANADA
    First Name:
    Clancy
    Truck Year:
    1988
    Truck Model:
    Engine Size:
    Cool, well I`ll pay attention to your progess!
  11. Stumpuller6.5
    94
    Mar 30, 2012
    CANADA
    First Name:
    Clancy
    Truck Year:
    1988
    Truck Model:
    Engine Size:
    Well I was supposed to be out of town today and for the rest of the week but job got pushed back a day, SO. I picked up a front seal for the PS pump, some cheap 15w-40 and some Rislone and $5 oil filter. Got home and removed the PS pump and R+R`d the front seal (it was hard as a rock), filled it up with some left over ATF from the garage and its good now. I filled the cooling system with about 10 quarts water ( :eek: ) and could not find a leak any were. I ran it until it got up to temp (the temp gauge works!!) then dumped the oil and filter, put in the cheap 15-40 and rislone and ran it a bit more. I checked all the lights and they work minus one clearance light in the RR tail light and none of the roof lights work... That`s all I did today, I`l let the rislone sit in it for the rest of the week and break down any deposits inside. *Oh, forgot to mention not even a spec of metal on the Drain plug! :thumbs:
    Hopefully on Saturday I will change the oil over to the good stuff and flush the PS. If I get really carried away I may change the oil in the trans and pop the rear diff cover and inspect and fill with new oil. (ALL AMSOIL BTW!) :rocker:
  12. HotRodPC
    HotRodPC Administrator Staff Member
    46,071
    6,571
    First Name:
    Truck Year:
    85 K20 LWB / 86 K5
    Truck Model:
    Silverado / Silverado
    Engine Size:
    454 - Turbo 400 - 3.73 350 - 700R4 - 4.10
    So you got all the fluids converted to Amsoil now??? Anything new on this project?
  13. Stumpuller6.5
    94
    Mar 30, 2012
    CANADA
    First Name:
    Clancy
    Truck Year:
    1988
    Truck Model:
    Engine Size:
    Ah man, work has been very busy, Just got home Friday from being away three weeks, have a lot of home things to catch up on first. I need to replace the batteries, they are tiny and don`t hold a charge very long. Thinking of getting a couple big Odyssey batteries. Still need to finish fluid changes. :grd:
    Still need to install drivers window and do the tanks... check the rest of her out to get it to past mechanical. I hope to have some time this week. :D
  14. HotRodPC
    46,071
    6,571
    First Name:
    Truck Year:
    85 K20 LWB / 86 K5
    Truck Model:
    Engine Size:
    Well, at least you have a good excuse. I don't shit done to mine hardly either and I'm home everynight. :shitsweak:
  15. Stumpuller6.5
    94
    Mar 30, 2012
    CANADA
    First Name:
    Clancy
    Truck Year:
    1988
    Truck Model:
    Engine Size:
    FInally had a day off, aside from catching up in family life I inspected the General. And pretty much as expected its not perfect! :lol:
    Must do list, for inspection.
    Windshield*maybe, has two chips, may or may not pass*
    Wiper blades and multifunction switch *only rinse works...:wtf:
    One LT215/85 R16 Tire *what a freakin unicorn size!* :frustration:
    Fuel Filter *needs it, not for inspection, just feel goodness. :D
    RH outer tie rod
    All Ball Joints upper and lower
    Rubber collar on steering shaft
    Front and rear sway bar bushings
    Rear brake hose *will try to get a stainless braided unit*
    Both rear park brake cables.
    Rear axle seals *will change them when I have the drums off to do cables
    Fuel tanks saddles (all 4)
    2 U joints
    Gonna shop online for most of this stuff, and for the front end components I will cheap out as they need not last to long before I do the 4wd conversion. :)
Share This Page
