Minor body rust solutions
88suburbanoverlan
oklahoma
uncle nick
suburban
v8
Any suggestions on addressing minor body, rust and surface rust for a few places on the body and the door jams? I also have quite a bit of surface rust on the roof from the paint being burnt off.
I currently have a vinyl wrap on the truck as pictured, and as I peel away each panel, I would like to get it primed and sealed, and as level as possible, so I can prepare it for the new wrap.
Am I correct to approach it as follows? Please advise for anyone with bodywork experience:
I was going to sand the rust spots in the door, jam and lay enamel primer spray on the sections as needed.
For any bubble rust on the body panel, I was going to send that down with 80 grit and polish it to 220 and then lay down enamel primer where needed.
I have already feathered the paint where there are bare metal spots so I’m wondering what I should do when I peel off the vinyl? Can I just spray a few coats of primer or better yet? Do a roll-on application since I’ll be doing it outside and then send that down to 1000 grit to get rid of some of the high and low spots?
On the roof, I was trying to avoid sanding, so I was hoping I could roll on the Eastwood rust encapsulator paint, followed by a coat of enamel primer, and then let that cure and lay some white paint over it.
I’m looking for the path of lease resistance here so I have a good surface with no rust. That is good enough to put another vinyl wrap on.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
If all I was going to do was wrap this truck...
I'd sand it clean, brush a couple coats of Rusty Metal Primer on it, hit that with 380 after a day, and wrap right over it.
88suburbanoverlan
oklahoma
uncle nick
suburban
v8
Is there a roll-on version of what you’re suggesting, sir?
I think that’s the most evasive idea and I definitely agree with you. I would need a roll-on application because I’m on an island basically with heavy wind and I’d be doing this outside.
Since I can’t wrap the door jams, do you have a suggestion for addressing those rust spots and maybe spraying the original color to finish it up? Reason I ask is because I’m going to wrap it the factory color so the door jams will match
I would also top coat the rusty metal primer or your enamel primer with some kind of top coat it doesn't have to be nice,or expensive. It just needs to seal the primer. Most primers are porous and moisture will leach through the primer and rust the metal under the primer. I'd hit the rust spots with ospho and roll rustoleum right over it,ospho the door jams then rattle can them. OSPHO neutralizes rust and you can paint enamel right over it. You have to knock off the loose stuff wash thoroughly with WATER based cleaner,spray with OSPH I use a garden sprayer wait 24hrs then topcoat.
Jrgunn5150
Ionia Mi
J.R.
6.slow
You can roll it if you want, doesn't matter, it's just Rustoleum, goes on thick, dries like iron.
The Right side of Washington
Depends what you’re after for finish. Wrap doesn’t hide anything so keep that in mind.
Wrap is also not cheap, albeit less than half the cost of paint materials, you’re gonna spend some paint budget on the roof and patches.
I wouldn’t wrap right over primer personally. Hit any primer areas with a couple coats of single single-stage to seal it well. Not very costly in the grand scheme of things.
Wrap is also not cheap, way less than quality paint, but…
As recommended I’d seal all primer. Couple quick coats of single stage imo.
rancher1913
Colorado
brian
c10, k5, k30
i used rust converter in the hard to get spots like seams. i used a syringe and needle and injected it into cracks. check under your body and make sure its not comming up from below, the seams in the door frame from underneath are spots to watch. if you want to kill the rust, use a sandblaster and fine sand, then an epoxy or 2stage primer to give it good protection, you can get the epoxy or 2stage in a spray can that makes it easy to do small areas. i seam sealed the seams under the cab after treatment and so far nothing has come back
Because AI and Google give incorrect directions. Here is a link to Skyco/Ospho site. How would they put epoxy in a spray can? It is a chemical reaction not air dried. Do they have a vial in the can you shake and break? I'm trying to figure this one out. You can spray Ospho from a garden sprayer the wand will reach some incredible places.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Because AI and Google give incorrect directions. Here is a link to Shyco/Ispho site. How would they put epoxy in a spray can? It is a chemical reaction not air dried. Do they have a vial in the can you shake and break? I'm trying to figure this one out. You can spray Ospho from a garden sprayer the wand will reach some incredible places.
They have two stage paint cans where you puncture the bottom of the can when you're ready to spray.
I really think people over think all of this and don't want to hear it, but whatever lol.
Thanks,that's cool. I've always mixed epoxy or urethane. Then tried to beat the pot life.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
If you watch The Blues Brothers movie closely, you can see that the can of spray glue Elwood uses on the motor home gas pedal is labelled "Marine Epoxy". I keep wishing that spray can epoxy was a real product..... Have done quite a bit of mix and apply like crazy, also have mixxed too much at once and had go into thermal runaway. A boat builder friend told me the trick of mixing a cup of the stuff and then embedding that cup in a larger cup full of ice to slow the reaction time down for increased working time.
I have seen the clear coat sprays with the punch in bottom that you use to combine the 2 parts at use-time, assume that is a single use can once you initiate the mixing. I have not used one yet.
NLD79K10
Netherlands
Lars
You normally need to use up the two-pack "mix-in-can" epoxy primer spray cans within a limited time of activating the hardener release (I've seen these cans from various manufacturers with a "use within" period from 6 hours to 4 days at 68F/20C). It pays to work out how much area you can cover with the can and prep as many areas needing a hit of primer as possible in advance so you can hit them all within that window. I normally use these sort of cans for smaller areas so I don't need to spend an additional bunch of time cleaning my spray gun.
79TanSquare
