In the meantime while waiting on bearings, I figured I might as well break the heads down. So I started with the pass side head. De valved it.
All the valves had soot and carbon buildup, I vacuum checked all of them, none of them hold a vacuum very long. Exh side is pitted.
So i lapped them all , and got them all to hold a steady vacuum with the valve in place with no spring pressure.
While I was there I gasket matched the exhaust ports and opened then up a little behind the valve and in the pathway leading to the primary.
Before
After
mostly doing this to keep cylinder pressure down as blowers create alot of it.
Tomorrow ill work on the drivers side.
