Low idle voltage
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
Kast night after work I was waiting on my truck to warm up before I left, with the headlights and radio on, my volt meter was just barely above the red. Is this normal, or is there something that would cause this? Battery and alternator are good, it reads well over 13 volts driving down the road. It just drops when idling.
yevgenievich
Viktor
sad
very sad
less sad
Pulley size on alternator wrong size for motor/belt or alternator failing
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
If you have a multimeter or access to one, test battery while idling and reving to see if there is much difference. Idling should read approximately 13.5 - 14.5 V. If reading increases at higher RPM's and decreases at idle, I would say alternator bad.
That and it's a quick way to tell if the dash gauge is accurate at all.
yevgenievich
Viktor
sad
very sad
less sad
Actually, talking about gauge accuracy. A poor body ground will make the gauge read decently lower than it should
yevgenievich
Viktor
sad
very sad
less sad
There is a ground to the core support, to the engine block and from engine block to firewall by rear passenger side head. But test with a voltmeter should be done first
Snoots
Roger
Jimmy Sierra
Which ground should I check?
All of them.
Not trying to be a wise-arse. But it is best to check them all.
Just start at the front and work you way to the back one-by-one. Take 'em off, clean the surfaces, add a touch of copper infused anti-seize and reinstall.
If ANY of the screws or bolts that hold down a ground wire are rusted, replace it. It ain't worth the headaches to try and clean them up. If they're rusty, they're toast.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I had that same problem on my truck. Idling at a stop light with heater fan on, headlights on, and heaven forbid its raining and I have the wipers on. Volt gauge would be down to where yours was or even lower.
I bought a smaller pulley for the alternator. This helped a bit- then when I added fuel injection I went from the stock 10si alternator to the 12si alternator. It makes a LOT more current at low (idle) RPM.
Typical OEM ratios are around 3 to 1, which simply means the crank pulley is three times the diameter of the alternator’s pulley. So in my case the engine would idle at 550 RPM and the alternator is spinning about 1650 RPM. So maybe I was making 16 amps? Slightly smaller puller and the 12si then will put out maybe 30 amps.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The GM Cs130 alternator is a easy upgrade, with current capabilities up to 105 amps basically at idle. It’s a easy upgrade over the 12Si most of these trucks came equipped with.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I looked at the CS130. It is better than the 12SI at idle. (Looks like about 40 amps) And it wasn't quite as plug and play, but still easy to install.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I did the CS130 swap on my Olds probably 20 years ago. I can run the heater in the car, headlights, the bottle heater for the nitrous, electric fuel pump, basically anything electrical and the voltage gauge never moves. I did have to swap pulleys (the CS alternator had a multi groove pulley for a serpentine belt) I can load test the alternator to its max output with no belt slip.
The nitrous and bottle heater are intended for those late night grocery trips. Gotta get that ice cream home before it melts!!
mitchell1128
