- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Good stuff.
That CC FordYou must be registered for see images attach
Trans back up in place
Transfer case reinstalled.
Just need the lube locker gasket to arrive, install the new filter and fill the trans and t case up with fluid.
Also ran the forklift out of propane (knew this was going to happen sooner than later). Dad perhaps a bit begrudgingly, grabbed the one off the lift at his work and brought it up for me to borrow to move it back into the other unit. Also it runs much better with a not empty tank. Who would have thought.
It really was a when not if type situation. I bought a forklift last night. 1961 Towmotor 400PLP. 2000lb, pneumatic tired machine built from 1951 to 1962. Have to measure but it's either a 9 or 10 foot lift.
Took it to the carwash and hosed it down some.
Got it unloaded and promptly got it stuck... That area is loose 2" rock, and over a foot of fill. Had to use the 8N to pull it out. Try to avoid that area again...
You must be registered for see images attachYou must be registered for see images attach
It's got a Continental Y112 4cylinder, it runs ok but could use a tuneup. Who knows when it last had points cleaned and adjusted. Says 9k hours on hour meter, not that that means anything.
It needs some love, and brakes (hydraulic, master looks similar to a 50s Chevy), the handbrake lever is missing, the drum on the pinion for the handbrake is still present. Manual transmission with high and low.
You mean dropping the forks or using the load as an anchor is an acceptable alternative to brakes?
I'll have to keep that in mind.
Yep.
For about 10 years now, we've had basically non-existent brakes in the shop forklift. Ever since my buddy used it to move large square balers down the gravel hill, lol.
*edit* no, the forklift is not meant for use on gravel, but it often goes on excursions outside the shop.
