Legopnuematic’s Shop Projects
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
I enjoy reorganizing the shop just as much as working on my trucks, feels so good when you're done
I always lose everything once reorganization has been completed. Leave it alone...lol...
legopnuematic
Licensed Junk Dealer
MO
Spencer
Got the Toyota wrapped up for now. I will be finishing the fog light wiring and new tie rods and oil pan gasket sometime soon. And it started to rain, a lot.
Dropped it off for its inspection before going home.
legopnuematic
MO
Spencer
Greg and I attended the Mopar blast this past Saturday. Brought the dart out and peddled some parts.
He paid for, and used the whole tire.
legopnuematic
MO
Spencer
Sunday this arrived
Still has the original style steering assist ram.
legopnuematic
MO
Spencer
It needs a pinion seal bad. 4 wheel disc brakes, way bars front and rear.
Before the 57 arrived I had done some tidying up around the shop.
Won't be long to looking like it normally does I'm sure.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Entropy is a Bit¢#. :(
legopnuematic
MO
Spencer
Liberated most of the harness from the 57. Overall things are in pretty reasonable shape, but there are some interesting things done over time. It had a later GM column in it (and now has a Saginaw style speedway motors unit) and this is how they had the connector wired in.
This is where the original fuse box would have been, lots of wire tap scotch loks on this. Yuk.
So I unwrapped the harness tape and began doing my stuff here. I believe I have mentioned before, but all of the power feed and distribution is being fed from the center console of the car now for accessibility. That means pulling the original feeds back through the harness to get them into the proper location.
legopnuematic
MO
Spencer
These originally are point to point wiring on the cluster, I am making it into a "harness" and adding a plug to make it easy to disconnect and reinstall as an assembly.
Using a delphi GT280 unsealed connector like I am on the 79.
Also removed the original radio wiring, heater control wiring (retro sound and vintage air).
The pile of removed wiring thus far.
legopnuematic
MO
Spencer
The owner dropped off some parts, the tach, oil pressure and temp, and reverse lights kit.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
At first I'm reading your post and looking at the pic with the heat-shrink connectors and thinking That's not so bad...
Then I started scrolling. :eek:
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Where is the battery mounted @legopnuematic ?? Gotta figure out a place for the battery in the Nomad.......maybe in the spare wheel well??
legopnuematic
MO
Spencer
@Blue Ox it really could be a lot worse. I’m sure it was mostly functional. Really teetering on the functional but ugly and not best practices see saw.
This car has the original harness, then a later GM harness was ran parallel to the original stuff, pretty clever since that gets you the wiring for a three wire alternator and such.
Whoever was responsible for the wiring before really liked using big zip ties, probably 8” long ones, with the tails cut about an inch long at a 45° angle! Might as well just taped razor blades under the dash. It took about the same time to free the harness from the dash that it did to actually remove it and start into it on the bench.
MoGold
