Keyless entry upgrade
KennedyHill
Louisiana
Joey
I am in the middle of an LS swap on my ‘87 square and I’d like to add the body control module from my donor to operate a keyless entry function on the truck. I have all the schematics, but I’m not having any luck on getting it to work correctly. Was wondering if anyone has any suggestions as to what to do. Thanks!
KennedyHill
Louisiana
Joey
My donor is an ‘02 GMC Yukon XL
grummy
Midwest
C1500
Ugh.. You never know what you run into with anything that had a computer. Probably throw a code if a wire is broke ! It also might need all the other circuits the body control module operated before a single function would work.
Sorry I'm no help.
I cheated and just bought a $25 Amazon 4 Door Power Lock kit with keyless remote(s). It sure is nice not having to lean over across the cab. It even locks both doors just when I lock mine on the way out. Sadly I did have to pull the doors and drill everything. I used factory Wire boots though. Good Luck !
Broken85
Cumberland, NJ
A
I added this little guy two years ago. Wiring wasn’t a major pain and it is still working just fine. Since it triggers the locks by bypassing the switch, it actually is much stronger than using the door switch which in my truck barely has enough power to raise and lower both locks.
Chris64
San Diego
I used to install alarms. GM are a pain compared to most vehicles in that you can't just send a signal to the switch wires. You'll need 2 Bosch style relays.
IIRC the wiring was
85 to remote controller, 1 to lock and 1 to unlock
86 to power (assuming the remote sends a ground signal)
30 to actuator positive, relay 2 30 to actuator negative
87a to ground
87 to power
You need to send the actuator a positive and a negative.
I just found a picture that also describes it - almost the same as what I said (85 & 86 are interchangeable)
Correction: you got me thinking about this, it's been like 30 years, I think you needed to interrupt the wire from the switch to the solenoid. Still two relays but I think 87a goes to the switch side and 30 goes to the solenoid side. You can tell if the solenoid lines are grounded by default. If you cut one of the lines and apply power only to the solenoid side it locks. I highly recommend you roll the windows down before doing this. I can't tell you how many installers locked the keys in the car while adding door locks.
Camar068
Air Force Supporting Member
10 yrs Air Force
I did the same but the one with the solenoids that direct mount to the lock arm. Wanna say it was $25 for a 4 door. Careful of the screws that clamp on the arm tho....mine stripped out pretty easy.
grummy
Midwest
C1500
I know what you mean. The OE rods are a larger diameter than what the clamps are made for. I removed the OE rods, thinned them out with the grinder in the area the clamps are installed. There was no way the clamps would work properly without doing that.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
I used a serial but radio w/XM Satellite from a 2005 LeSabre in my '84 Caprice. I added the Keyless entry with the security system features shortly after. In that vehicle (and probably others), the Dash Interface Module (DIM) is the Power Mode Master. I also used the Instrument Panel Control Module, many times call the Body Control Module. You would also need the Driver's Door Module for an actual +12v/-12v to the door lock motor. I sent this signal to the OEM door lock relay in the car. I did not set up the system as progressive, i.e. one remote button push for drivers door only, 2 pushes for all doors. You would also need Remote Keyless Entry control module as the antenna for the system. It also is matched to the remotes. Some GMs of this era cannot be programmed for new remotes without a Tech 2 type scan tool. Taking this module with already matched remote(s) is the way around this.
I also had to use the Rear Interface Module to use the trunk release function for the car.
The remote receiver is just a little module.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
I even ended up with Driver 1 & 2 remotes eventually. I was shocked to find the radio presets were specific to each remote / driver too!
trash_panda
Alabama
Shannon
I am about to attempt this in my Squarebody. The BCM in a 08 Tahoe is the Power Mode Master. Only thing I don’t have is the driver door module. I’m hoping after the remotes are programmed it will send the signal out of the BCM door lock and unlock control wires.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
Sounds like fun! Was GM still using a separate RKE (Remote Keyless Entry) module in the '08 with the GMLAN system? IIRC some trucks had a RKE module near the top of the dash on the passenger's side.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
Answered my own question!
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
I tried looking at your driver's door module, but it doesn't appear on RA anymore. They didn't use to require programming. I don't recall if they were automatically programmed with the VIN on first power up (like some Power Mode Masters and XM Modules), or if they operated without that non-sense all together.
