Huck's daily - 2005 Z71 crewcab
Relp Raggy!
I think I'll be able to have it yanked and on the stand Thursday night. Then come up here Saturday for the full teardown. I'm hoping me running it low on oil during that trip is what did it and I'll get away with just bearings. I'll have to mic the crank to see, may end up sending it to one of my machinist buddies for a good polish job and just have them look over everything
bluex
Spartanburg SC
C15
Dammit Paul, beat me to it lol
That is the first thing that pops in my head anytime anyone says "bet you won't do that anymore" :rofl:
You'll also get a sarcastic "really, really" out of me if you ask me really?
Edit: on a side note, this is now my worst fear with the jeep. I'll finally get to start driving it an it will grenade again :bawl:
legopnuematic
Licensed Junk Dealer
MO
Spencer
Bird box oil changes going forward…
I say the "really really" fairly often too :rofl:
I got the intake off at lunch and before putting the lift plate on, I spun the motor to look at what I could of the cam lobes. All of that looks fantastic, I'm really thinking it was me running it too low on oil that did it. So just don't do that lol
Hunter79764
Grand Prairie, TX
Suburban V20
(As I think about the 3 times in the last month that my 6.0 in my Daily has given me the "Low Oil Level" light as I'm due for an oil change and have a leaking rear main...)
Pulled the heater hoses and water pump off earlier, of course made a huge mess. So I just jacked the back of the truck up to drain more out of the block cuz why not :rofl: Threw kitty litter down after that. Thankfully I stopped and got another bag last night, 48lbs for $15
Gotta lay the PS pump/bracket off to the side, same with the AC, support the Y-pipe with a bungee, pull the manifolds, undo the motor mount bolts, couple more wires and then it's just bellhousing bolts and yank it.
Hunter79764
Grand Prairie, TX
Suburban V20
Did you remove the crank pulley yet? I fought one out with the pulley on, fought triple trying to get it back in later before I pulled it off and reinstalled it in the truck. Life was much better that way, but I didn't have the right combination of heat and torque and skill to do it all the right way.
Then when repairing wreck damage on a different one years later, I realized the upper radiator support crossbar comes out with just a couple of 10mm bolts, which would have made it a piece of cake to remove the engine but not provided as much protection for the grill and AC condenser if it swung the wrong way. You might know all of that, I just learned it the hard way and want to share if it helps anyone.
legopnuematic
MO
Spencer
No, I leave the crank pulley on. With the fans removed, it leaves about 1" of wiggle room, no problem at all getting it out as long as you don't let the flywheel catch on the plastic cowl cover. One thing I did do different this time was pull the exhaust manifolds out first, was alot easier getting it past the harness without those to snag on.
None of my 5.3 trucks have ever had the removable crossbar, though you're not the first I've heard say that. I wonder if some of the other engine combos had that
79TanSquare
