Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
I swapped a lightly used 600 (that was on a 350) in place of the under achieving 390 the truck came with. Had an issue where the rear float was dry and the idle was way high.
Got both floats set perfectly - set the idle screws.....everything topped at about 18-19 inches of vacuum. Gauge said it was all in the normal range. The screws were way out to begin with....had to turn them in about 3-4 complete turns just to start. Once those were set the idle wasn't screaming high anymore....but is also as low as it can go (idle screw).
So I take it around the block......anything over 20-25mph and it just shuts off - thats basically ANY pedal action. I toss it into neutral and restart.....keep going but 20-25 is it. Like its just at idle. ANY acceleration and it doesn't backfire or stumble - it just shuts off. When sitting in park, I can rev it and it sounds and acts fine.
No one around here knows anything about carbs anymore - probably waiting on an app for their phone. Screwballs at a nearby 'speed shop' said to bring it by and they'd try. Oooooh....actually try? Wonder what that would actually cost? I'm done with it.
