1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
"Hank" 1984 Chevy Suburban 2500
Discussion in '4wd Suburban, Blazer and Jimmy' started by BW Customs Co, Aug 5, 2019.
  1. BW Customs Co
    BW Customs Co Junior Member
    23
    45
    Jun 22, 2019
    Belgrade, MT
    First Name:
    Crispin
    Truck Year:
    Truck Model:
    Suburban
    Engine Size:
    Running a 6L80E. Shifter is a LOKAR ESS. I had to have it done at the factory by them because the gen V LT motors need a separate gear for tap shifting. EDIT: just a 2" lift and 255/85R-16's. Not a big fan of really fat tires on older trucks.
    Seats are from LMC done by TMI. I custom made the center consoles and had them upholstered locally to match.
  2. TubeTruck
    TubeTruck I like anything fast enough to do something stupid
    937
    1,135
    Sep 4, 2019
    Northern IL
    First Name:
    Denis
    Truck Year:
    1978, 1975
    Truck Model:
    Suburban K10, GMC K15
    Engine Size:
    400ci, 350ci
    Hrm. Now you got me thinking. I pulled an efi 454 and 4L80e to drop into my Suburban. I was looking at shifter options and saw the Lokar. Still debating if I want to use a floor shifter or buy a junk column and build a way to get all the gears on a 70's column. I like the 6L80e option though.
  3. BW Customs Co
    23
    45
    Jun 22, 2019
    Belgrade, MT
    First Name:
    Crispin
    Truck Year:
    Truck Model:
    Suburban
    Engine Size:
    6L80E is as pain to work with - not a lot of controller options. I'd stick with the 4L80E. Lokar ESS shifters are very well built, I definitely like the floor shift. I custom fabbed up a spacer box to raise the whole unit up and tilt it back a bit so it would look the best.
    TubeTruck and Craig 85 like this.
  4. Holl
    Holl Junior Member
    13
    Jul 6, 2017
    First Name:
    Rich
    Truck Year:
    Truck Model:
    suburban
    Engine Size:
    Great Truck! did you bolt the side steps you fabbed to the frame? if you get a chance, photos would be great....thanks.
  5. TubeTruck
    937
    1,135
    Sep 4, 2019
    Northern IL
    First Name:
    Denis
    Truck Year:
    1978, 1975
    Truck Model:
    Engine Size:
    400ci, 350ci
    So I'm seeing P-R-N-OD-D? Then side shifting you get 2nd and 1st gear? Do you have to hold it to the side or does it detent over (kinda looks like it did but want to make sure)? I am looking for a ratcheting shifter for my 4L80e. When I build a wheeling truck I want a full manual with a ratchet shifter. I had a full manual with a TH350 and a B&M ratchet and I absolutely loved it.
  6. BW Customs Co
    23
    45
    Jun 22, 2019
    Belgrade, MT
    First Name:
    Crispin
    Truck Year:
    Truck Model:
    Suburban
    Engine Size:
    Yes, right to the frame. I'll snap some pictures when I have a minute. I drilled new holes and tapped them. Very solid.
    P-R-N-D-M
    When in manual mode I can shift from 1-6 gear. It detents over and is very nice. Good clicky action
    TubeTruck likes this.
  7. BW Customs Co
    23
    45
    Jun 22, 2019
    Belgrade, MT
    First Name:
    Crispin
    Truck Year:
    Truck Model:
    Suburban
    Engine Size:
    Here you go!
    Derick C. and Craig 85 like this.
  8. Holl
    Holl Junior Member
    13
    Jul 6, 2017
    First Name:
    Rich
    Truck Year:
    Truck Model:
    suburban
    Engine Size:
    Thanks!
  9. BW Customs Co
    23
    45
    Jun 22, 2019
    Belgrade, MT
    First Name:
    Crispin
    Truck Year:
    Truck Model:
    Suburban
    Engine Size:
    Took it out for its first 10 mile drive today to let the 6L80 learn to shift.
  10. BW Customs Co
    23
    45
    Jun 22, 2019
    Belgrade, MT
    First Name:
    Crispin
    Truck Year:
    Truck Model:
    Suburban
    Engine Size:
    Also here is a walk-around video.
    The88, Derick C. and HotRodPC like this.
Share This Page
