1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Grandpas farm truck lives on!
Discussion in '2wd Pick-Ups C/R 20 2500 C/R 30 3500' started by 02ta-ws6, Jan 5, 2016.
  1. 02ta-ws6
    02ta-ws6 Member
    35
    Jan 5, 2016
    NE pa
    First Name:
    dustin
    Truck Year:
    Truck Model:
    c30
    Engine Size:
    6.2 diesel
    All cleaned up, loaded up, resurrected, back on the trailer.....
  2. CSFJ
    CSFJ ----------------- Supporting Member
    6,154
    4,930
    Jul 1, 2014
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Looks good. Pretty much what I have to do to mine, except you had a good cab and clip to work with. Where did you source your spring packs from? I brought home K30 frame for mine a couple weeks back, and the packs on it have more broken leaves than good ones. lol
  3. 02ta-ws6
    02ta-ws6 Member
    35
    Jan 5, 2016
    NE pa
    First Name:
    dustin
    Truck Year:
    Truck Model:
    c30
    Engine Size:
    6.2 diesel
    I know I may be beat up for this a bit but I wanted to clean up the extra set of rims and hit them with some fresh paint. Had to have the good tire taken off the crappy rims and swapped over so don't mind the over spray....no Fs given on my part haha
    It was a 60 dollar freshening up when you take into account the cost of them getting swapped. Much cheaper than a new set of rims.
    Getting closer....
  4. 02ta-ws6
    02ta-ws6 Member
    35
    Jan 5, 2016
    NE pa
    First Name:
    dustin
    Truck Year:
    Truck Model:
    c30
    Engine Size:
    6.2 diesel
    Yea both trucks had broken springs as well. Also they were a pita to get out....I was loosing my head. Had to cut the heads of the bolts off and pull them through by stacking washers and kept tightening the nut to do so.
    I got them from a buddy of mine that works at his dad's spring shop. They mainly do customs springs and make their own for big rigs. Factory springs were rated for 2800 lbs and these were a heavy duty 3200lbs spring pack. He had them for a guy that never picked them up. Got them for 650 which included everything u-bolts, cups, bolts and nuts etc
  5. CSFJ
    6,154
    4,930
    Jul 1, 2014
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Good to know. I haven't started pricing anything suspension wise yet, Still need to get my frame stripped and sent to the sand blaster.
  6. 02ta-ws6
    02ta-ws6 Member
    35
    Jan 5, 2016
    NE pa
    First Name:
    dustin
    Truck Year:
    Truck Model:
    c30
    Engine Size:
    6.2 diesel
    Props to you for getting it sand blasted. It crossed my mind but since we were goin for getting inspected(with updated the obvious stuff) we tried to keep it lower $ wise
  7. 02ta-ws6
    02ta-ws6 Member
    35
    Jan 5, 2016
    NE pa
    First Name:
    dustin
    Truck Year:
    Truck Model:
    c30
    Engine Size:
    6.2 diesel
    After much deliberation...we finally decided on a flatbed goosebody (not that we would hook a 5th wheel behind it) . We have planned to build some wood sides for it and paint them gray like the original box. Took three days and they mounted up a knapheide bed on meant for a ford. They did an awesome job mounting, even put the fuel filler neck it the cut out on the bed.
  8. DoubleDingo
    DoubleDingo When In Doubt, Throttle Out
    6,380
    5,627
    Jul 3, 2012
    Right where I am
    First Name:
    Bagoomba
    Truck Year:
    1981, 1965
    Truck Model:
    Engine Size:
    That is some awesome history and good work. Thanks for sharing.
  9. 02ta-ws6
    02ta-ws6 Member
    35
    Jan 5, 2016
    NE pa
    First Name:
    dustin
    Truck Year:
    Truck Model:
    c30
    Engine Size:
    6.2 diesel
    Finally getting inspected 2 days before xmas...at this point my grandpa is living in an assisted living facility and doesnt know we this close. After a tie rod and a collapsed front brake line we are finally inspected again after almost 3 years!!! Got the crap rims and good tires swapped out onto the good rims and.......DONE!
  10. 87scotty
    87scotty Full Access Member
    29
    1,074
    274
    Oct 8, 2015
    Central il
    First Name:
    Andrew
    Truck Year:
    Truck Model:
    V20
    Engine Size:
    5.7 for now
    Looks great and great story
  11. 02ta-ws6
    02ta-ws6 Member
    35
    Jan 5, 2016
    NE pa
    First Name:
    dustin
    Truck Year:
    Truck Model:
    c30
    Engine Size:
    6.2 diesel
    So Christmas day I went to pick him up from the facility and he was happy...able to climb up in on his own and he seemed right at home. He though it sounds good and was running smooth. I asked him how I was doin driving his trusty old steed, and he said I was being nicer to it than he was haha...he used to take it in the woods for hunting and firewood so that could be true.
    Rims painted up...a little dirty overall but we got it done with 1 day to spare. It was a real learning experience and now I just want to keep working on stuff.
    I believe cousin and I had about 14 Saturdays into it with help from others here and there. I also had some extra days popping over to check on a few things as well. But all I all we are really happy with out it turned out. It's not show quality but I can and will by all means be used again for work and play. It is awesome to drive....ya just put around
    These were from xmas day after i got him back to the farm.
  12. 02ta-ws6
    02ta-ws6 Member
    35
    Jan 5, 2016
    NE pa
    First Name:
    dustin
    Truck Year:
    Truck Model:
    c30
    Engine Size:
    6.2 diesel
    Thx!
  13. 02ta-ws6
    02ta-ws6 Member
    35
    Jan 5, 2016
    NE pa
    First Name:
    dustin
    Truck Year:
    Truck Model:
    c30
    Engine Size:
    6.2 diesel
    Next part of this project is my grandpas uncle built a custom tool box a very very long time ago(maybe 50ish) don't know for sure but he had told my grandpa he wanted him to have it so this will be getting cleaned up and goin on next. Although it might be a spring time project at this point
    So maybe sandblast and paint black....havent thought about it much yet or even seen it in person
  14. 02ta-ws6
    02ta-ws6 Member
    35
    Jan 5, 2016
    NE pa
    First Name:
    dustin
    Truck Year:
    Truck Model:
    c30
    Engine Size:
    6.2 diesel
    Thx
  15. crazy4offroad
    crazy4offroad Service Bullshit Filter Soon
    49
    8,408
    788
    West BY-GOD Virginia
    First Name:
    Truck Year:
    Truck Model:
    One-Ton K-10
    Engine Size:
    350/TH350/NP205
    Hey this is awesome, and great story to go with it. Lost my dad last year and got his square and some days working on it I'll just get in on the passenger side with it idling and the radio on oldies and remember him driving it. Keep up the good work and let him know how much all of us here love his Ole Blue.
Share This Page
