Further tunning help.
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
Hey for the guys who know wat i have all done, anything i can check to figure out this little studder at idel or studder when you put her to the boards? It has to be in the carb. The motor does not have the slightest valve noise or knock or anything, the vac gauge is rock solid at 20, the timing balls on 6, new everything but my battery cables which the pos is spliced bad and the starter is old but seems to work good. Reason i bring that up is i remember someone saying he had one shorting out which caused problems.
I have brand new heads and ignition module and I still have a slight idle stutter too on my TBI 350.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Lance, I think you need more accellerator pump shot. Are you familiar with the parts on your carburetor? There are 2 holes for the accel pump rod, which is on top of the drvers side of the carburetor....looks like a teeter totter.
like dis:
Gfarms
