Found a mystery rod in my motor
projo198
Lawson MO
James
Today after pulling my intake and heads I rolled my motor over and this fell out. I have NO idea what it is, and don't recall seeing it in the valley under the manifold when I removed it.
Any ideas?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Any ideas?
Oil pump driveshaft. Hooks to the distributor.
carnutjw
Evansville, IN, USA
R20 Suburban
Should have a little nylon clip on the bottom "tongue" in your pic that keeps it from pulling out when you pull the distributor. It has a ring on the inside that clips into the groove on the shaft and the oil pump.
projo198
Lawson MO
James
Thanks guys. Guess it was important after all.
I've replaced it with a fixed sleeve one.
bajadiver
