1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
FoamyPirate's 1988 R20 Crewcab
Discussion in '2wd Pick-Ups C/R 20 2500 C/R 30 3500' started by foamypirate, Jun 22, 2015.
  1. bucket
    bucket Super Moderator Staff Member
    39
    23,442
    10,059
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Hey, ain't nothing wrong with that either. A cooler does a fine job of keeping the beer cold. Er, I mean sody pops.
    ajd89 likes this.
  2. bucket
    39
    23,442
    10,059
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    The throw is similar to the later aluminum-topped 465's that were used in the gmt400 trucks.
  3. ajd89
    ajd89 Full Access Member
    1,522
    730
    Nov 30, 2016
    Central Michigan
    First Name:
    andrew
    Truck Year:
    87
    Truck Model:
    Engine Size:
    :cheers:
  4. ajd89
    1,522
    730
    Nov 30, 2016
    Central Michigan
    First Name:
    andrew
    Truck Year:
    87
    Truck Model:
    Engine Size:
    So no worrys of it hitting the dash or seat? I mean its not the first time it's been done but just was thinking that wouldn't be good.
  5. foamypirate
    foamypirate Full Access Member
    31
    3,294
    377
    Pflugerville, TX
    First Name:
    Jake (Mr. Wilson)
    Truck Year:
    1988
    Truck Model:
    R20
    Engine Size:
    6.0L LQ9 - NV4500
    My LS swap mounts move the drivetrain forward, so I was a bit worried about that, but it clears with plenty of room. We'll see how comfortable it is once I get the bench seat back in. I may wind up with an SM465 style shifter (with the crazy bends by the floor) to move it a more comfortable spot.
    OkieFishMan likes this.
  6. BTeague
    BTeague Junior Member
    60
    Oct 16, 2017
    Arkansas
    First Name:
    Billy
    Truck Year:
    Truck Model:
    r20 crew cab
    Engine Size:
    Jake, I've been reading through your thread. I am doing an NV4500 swap in my 87 crew cab. What slave cylinder are you using?
  7. foamypirate
    31
    3,294
    377
    Pflugerville, TX
    First Name:
    Jake (Mr. Wilson)
    Truck Year:
    1988
    Truck Model:
    R20
    Engine Size:
    6.0L LQ9 - NV4500
    Since mine is being installed behind a 6.0L LS, I used the internal slave cylinder from a 2005 GM truck with 6.0L and an NV4500. Is your NV4500 external or internal slave?
  8. BTeague
    60
    Oct 16, 2017
    Arkansas
    First Name:
    Billy
    Truck Year:
    Truck Model:
    r20 crew cab
    Engine Size:
    External. I have everything but the hydraulics.My concern is the mismatch between the squarebody m/c and the slave cylinder that fits the bellhousing(1995).
  9. foamypirate
    31
    3,294
    377
    Pflugerville, TX
    First Name:
    Jake (Mr. Wilson)
    Truck Year:
    1988
    Truck Model:
    R20
    Engine Size:
    6.0L LQ9 - NV4500
    From what I understand, they should work OK together. The bore sizes are pretty much identical.
    Do you know what you are doing for hydraulic lines? I opted to use a -3AN brake line.
    You can adapt the Squarebody MC and the external slave cylinder with the following parts:
    MC to -3AN: EARLS BRAKE UNIFLARE ADAPTER -3 AN MALE TO 12MMX1.00MM - PART# 592053ERL
    Slave to -3AN: Russell Clutch Adapter Fittings 640281
    Here are some pictures I found of a setup with external slave and a SBC, with -AN lines:
    OkieFishMan and Honky Kong jr like this.
  10. BTeague
    60
    Oct 16, 2017
    Arkansas
    First Name:
    Billy
    Truck Year:
    Truck Model:
    r20 crew cab
    Engine Size:
    Thanks. Ill give it a try.
  11. foamypirate
    31
    3,294
    377
    Pflugerville, TX
    First Name:
    Jake (Mr. Wilson)
    Truck Year:
    1988
    Truck Model:
    R20
    Engine Size:
    6.0L LQ9 - NV4500
    Finally got a chance to make a little more progress on this today. I've been down sick, had parents visiting, came down sick AGAIN, and even though I'm still a little under the weather, I was tired of hogging up my friends shop, so I spent about 4 hours working today.
    • Clutch pedal position pigtail wired in and wrapped in dry vinyl harness wrap.
    • Fuse block reinstalled (though I may take this back out to fit a little more wiring between the halves. It appears my LS swap wiring may interfere with the clutch pedal throw as it's currently routed.
    • Brake booster, and master cylinder installed and pedal rod attached to brake pedal
    • Clutch master cylinder installed, line attached
    • Radiator trans cooler line looped, last of the hard lines removed.
    • Driveshaft installed
    • Transmission filled with 4 qts of liquid gold
    I still have to install the steering column, figure out the clutch/cruise wiring (think I need to add another wire to the PCM for this, ugh), find a place to mount my clutch reservoir, bleed the clutch, and reinstall my gauge cluster, dashpad, and seat, and it should be driveable, though not finished by any means.
    Random pics (I like gratuitous close ups so people doing similar stuff can see details they may be curious about):
  12. foamypirate
    31
    3,294
    377
    Pflugerville, TX
    First Name:
    Jake (Mr. Wilson)
    Truck Year:
    1988
    Truck Model:
    R20
    Engine Size:
    6.0L LQ9 - NV4500
    My NV4500 uses a monster 1410 U-joint. Makes my 3.5" driveshaft look itty bitty.
    That's a lot of shaft...hehe.
    Had to clearance the crossmember to clear my cats. Ugh.
    Rear view of the transmission.
    More clearancing...
  13. foamypirate
    31
    3,294
    377
    Pflugerville, TX
    First Name:
    Jake (Mr. Wilson)
    Truck Year:
    1988
    Truck Model:
    R20
    Engine Size:
    6.0L LQ9 - NV4500
    A view from underneath to the cluster-^%#$ that is the dash wiring, currently. :D
    Clutch disc sandwiched by flywheel and pressure plate.
    Small peak at the slave cylinder and fluid fitting.
    Through the bleed area looking at the pressure plate and slave cylinder.
    Better, brighter shot of the above.
  14. OkieFishMan
    OkieFishMan Certified Camping and Fishing Nut
    371
    200
    May 8, 2017
    Enid, OK
    First Name:
    OkieFishMan
    Truck Year:
    Truck Model:
    GMC C2500
    Engine Size:
    454/SM465
    Awesome work!
    foamypirate likes this.
  15. foamypirate
    31
    3,294
    377
    Pflugerville, TX
    First Name:
    Jake (Mr. Wilson)
    Truck Year:
    1988
    Truck Model:
    R20
    Engine Size:
    6.0L LQ9 - NV4500
    It's! ALIVE! Not completely finished, but I drove it about 10 miles home with no issues (other than a seriously blond moment I had when first leaving, lol). Drives sweet, but it's loud as all get out in the cab with no insulation/carpet, and a giant hole in the floor, lol.
    Testing the hydraulics to make sure they were all bled appropriately. The pedal effort on this thing is so light, it was throwing me off. You can depress the clutch pedal by hand, quite easily. However, as you can see, the pressure plate is pulled completely away from the clutch disc, so we deemed it good to go (and it was)!
    Taking a small break from working...check out all that leg room!
    The first daylight this truck has seen in about 2.5 weeks. It was nice to work on it in good light again, hah.
    Cobbled together a rudimentary bracket to mount the clutch reservoir.
    akchevrolet and Old77 like this.
Share This Page
