Fix Slamming Doors - Striker Door Latch Repair
hack_man
MA
Tony
I still have the original plastic on both strikers from 1983. I guess that's unusual.
I have to slam my door because the aftermarket door gasket is too thick.
Moderator Administrator
Just to make sure you're still paying attention 15 years later. So wth did it take you 2 days to respond? Huh? WTF?!?! Slacker !!!
And it took me even longer this time cuz I've been out of town working. What you gotta say now, Senor Fussy Britches? :D
JBF43
FL
C60
I have done this same thing many times in the past using old garden hoses that aren't good anymore for carrying water, but make great cushions on a closing door latch. Cut and installed the same way as the pex pipe.
Who is this? Shaggy hired another Admin? Name looks familiar but... I think I may have seen you around before. Maybe on other forums?
Cyrillious
Toronto
Cyril
K10 Suburban
That won't work for us Burban boyz, that back threaded plate will fall right off and down to the bottom of the 2 dooor pillar and you'lll be f'd.:baby:
Too late... I dealt with that situation... However I I fished out that plate along with insulation and whatnot and installed the proper replacement striker. It took some time and patience but it got done. Have your magnet and your sense of feel. Where there is a will, there is a way.
Cyrillious
Toronto
Cyril
K10 Suburban
Yep, if I was you Burb boys, I'd leave good enough alone and just put the pex on and be good to go. I didn't touch mine. Just put the pex on and its great. A gentle push from about 8 inches open and bam, its latched tight and a nice matching seem to the cab.
With the pex you will have to replace every so often. My right side is chewed up.
84GMCSierra
Supporting Member Air Force
Central Arizona
C2500
You don't think the white on a dark blue paint would stand out?
Only time it will be seen is when the door is open. I saw a brand new striker assembly online and the bushing is white. If you paint it,bits going to chip the paint, then it will really look bad
Fair point. I'll go ahead and move forward with the upgrade then
Stop being an ass
Just trying to make sure i do the right thing. :shrug: Luckily, someone just commented on my 15 year old post and I can move forward with the fix. I've been waiting all these for some confirmation and now that I have it I can move forward.
Mind your own business, newbie!
84GMCSierra
Central Arizona
C2500
84GMCSierra
Central Arizona
C2500
White truck, white pex. C'mon man, tighten up
I have a white truck and blue pex. Color doesn't mean squat to me. As long as my doors close without slamming I don't care what color it is
84GMCSierra
Central Arizona
C2500
I keep a few bags in my truck if they need some, I have them
79TanSquare
