Engine runs poorly spontaneously?
JBswth
Vallejo, California
James
C25
292 cubic inches
Have done a vacuum measurement on PCV port value = steady 16inHg at high rpm, see picture. Engine runs very poorly and make sucking noise when I let it run stationary, I make movie but can't attached it? Vacuum value is very low 4inHg
Sucking noise? Sounds like you have a vacuum leak - not a little one at that. I would inspect the intake manifold for cracks. You can spray carb cleaner or WD40. If you locate the leak(s), the engine will temporarily speed up and smooth out.
J. B.
motionz
Netherlands EU
M
BIG10
350ci
I ended up setting the timing advance to 10 degrees as a starting point (with vacuum connected 24 deg.) I can't really find a specific setting where it runs best; I notice the engine is slightly more responsive, but the effect is minimal.
For now, I'm going to get back on the road—thanks everyone for all the help!
omegashawn
