73c20jim
- Jun 11, 2018
- Tombstone, AZ
- Jim
- C20 2WD Custom Deluxe. C10 2WD Base Model
- 350 CID 195/260 HP Goodwrench crate, 400 CID 2bbl
P240KC E3212 Fuel Pump and Strainer Kit CHEVROLET MEDIUM DUTY TRUCK All Models 1994-1994 V8-454 7.4L Models w/ M.F.I. & 1.45" Diameter Pump. Some applications may require the use of the original tank flange seal.
P240KC E3265 Fuel Pump and Strainer Kit CHEVROLET TRUCK All Models 1992-1993 V6-3800 3.8L Models w/ M.F.I. & 1.45" Diameter Pump. Some applications may require the use of the original tank flange seal.
P240KC E3265 Fuel Pump and Strainer Kit CHEVROLET TRUCK All Models 1994-1994 V6-3800 3.8L Models w/ M.F.I. & 1.45" Diameter Pump. Some applications may require the use of the original tank flange seal.
P240KC E3265 Fuel Pump and Strainer Kit CHEVROLET TRUCK All Models 1992-1995 V6-3800 3.8L Models w/ M.F.I. & 1.45" Diameter Pump. Some applications may require the use of the original tank flange seal.
P240KC E3212 Fuel Pump and Strainer Kit CHEVROLET TRUCK All Models 1994-1995 V8-454 7.4L Models w/ M.F.I. & 1.45" Diameter Pump. Some applications may require the use of the original tank flange seal.
P240KC E3265 Fuel Pump and Strainer Kit CHEVROLET TRUCK All Models 1995-1995 V6-3800 3.8L Models w/ M.F.I. & 1.45" Diameter Pump. Some applications may require the use of the original tank flange seal.
P240KC E3265 Fuel Pump and Strainer Kit CHEVROLET TRUCK All Models 1996-1996 V6-201 3.4L OHV Models w/ M.F.I. & 1.45" Diameter Pump. Some applications may require the use of the original tank flange seal.
P240KC E3270 Fuel Pump and Strainer Kit CHEVROLET TRUCK ASTRO VAN 1992-1994 V6-262 4.3L Models w/ M.F.I. & 1.45" Diameter Pump. Some applications may require the use of the original tank flange seal.
P240KC E3270 Fuel Pump and Strainer Kit CHEVROLET TRUCK ASTRO VAN 1995-1996 V6-262 4.3L Models w/ M.F.I. & 1.45" Diameter Pump. Some applications may require the use of the original tank flange seal.
PLUS many, many other GM applications.
Price - Ride only.
Price - Ride only.
