judson_means
Peachtree Coners, GA
Judson
k2500
Hey All,
I’m working on my 1976 gmc k25. It came stock with dual tanks and return lines, but at some point the last owner cut out the return lines and I’m assuming slapped the single solenoid 3-port selector valve that’s in it now (added pic bellow).
I’m now looking to change it back to a 6-port valve and restore the return lines, but from my research I’m seeing that I have to redo to wiring b/c they don’t make single wire 6-port valves anymore. I’m not completely enthusiastic about tapping into the wiring harness, 1. b/c that’s not my strong suit, but 2. B/c it’s already been cut up pretty bad from the last owner.
What’s my best course of action here?
Likewise I had troubles with the fuel gauge before I realized the valve was wrong. So also, would it be worth it to upgrade to 3 port sending units that have vapor lines as well (if I end up having to replace sending units), since I plan on towing in the hot south.
Thank you!
NLD79K10
Netherlands
Lars
A 2-wire valve can easily be controlled using a single pole dual throw relay to switch power from a fused accessory power source to the valve to shift it to either side. It basically requires a 5-pin switching relay (SPDT), a wire tap into ACC power (preferably with an inline 7.5A fuse for a bit of additional safety) going to pin 30 on the relay, the original single wire going to pin 86 on the relay, a ground wire to pin 85 on the relay and pins 87 (normally open) and 87a (normally closed) providing the outputs to the D and E inputs on the 2-wire valve. The 5-pin relay basically replaces the toggle switch in the attached diagram (ignore the fuel pumps in the diagram, that is only for use with EFI systems) and changes the power coming from pin 30 going to pin 87a when no power is applied to pin 86 to going out to pin 87 when power is applied by toggling the selector switch on the dash.
judson_means
Judson
k2500
Ok, so if I add the 5-pin plug for the new selector valve, will I also have to change the switch in the cabin that flips the tanks, b/c my truck (1976) originally had a single wire selector valve.
NLD79K10
Netherlands
Lars
Don't need to change the switch at all, if you read my previous reply the actual switching is done by the relay, power being applied from the selector switch throws the relay output which then applies power to either side of the 2-wire selector valve. The relay essentially replaces the toggle switch in the diagram I provided. If I get the chance, I'll draw up a more specific diagram for you today.
NLD79K10
Netherlands
Lars
Took me a bit longer to get back to this thread than I thought, but here's the basic schematic to control the 2-wire valve using the original 1-wire toggle switch.
[edit]
If you need to change the valve feed direction due to it drawing from the wrong tank compared to the switch label, all you need to do is change over the wires going to contacts D and E on the 2-wire valve connector on the relay side, that's a lot easier than de-pinning the connector and switching them over on the valve side or yanking the switch and mounting it upside down :)
NLD79K10
Netherlands
Lars
@judson_means Minor screw up on my side, I forgot that the newer FV5 5-pin valve uses voltage differential between pins D and E on the valve to change the flow direction of the valve. The old 6-pin valves had a dedicated ground on pin F that allows my previous schematic to work. The setup in the attached schematic should work on the 5-pin version by using a DPDT relay to flip the valve direction by switching the polarity of pins D and E.
MoGold
