Direct power headlights need fuse?
73c20jim
Tombstone, AZ
I installed the aftermarket "direct power to headlights" wiring harness. The direct power to the headlights main power connect directly to the battery.
Since we now bypass where the headlights got their power OEM, was that circuit fused???
Do I need to fuse the new direct power to headlights circuit ???
Rickf
Grafton NH
1974, 1954 & a 1937
The kit I installed came with a 30amp fuse. I thought the lighting came from a fusible link off the starter solenoid.
Ellie Niner
Tucson, AZ
Tory
K10 Silverado
LE9 305
Yes. Fuse size is based on minimum gauge of wire in circuit.
73c20jim
Tombstone, AZ
Then 30 amp it shall be.
ssgmike
