Cruise control Delete
Turbo360
Idaho
Kevin
I might be early on this, but if you're going to remove the whole unit, I would be interested in buying it from you. A relative of mine has a '76 C10 without cruise which he normally prefers to have, so I could get this one working and put it on his truck.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
@Turbo360 yeah, I would say yes, but I would not want to get your hopes up.. I have a feeling it is frozen up and that’s the reason it snapped the cable clean off. I will take it off this afternoon and see what shape it’s in..I will post the findings here soon enough. But I have to work on a late model plate of fried catfish n potatoes soon and possibly a nap lol
Turbo360
Idaho
Kevin
Sounds tasty! Thanks for the update.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
Follow up it was stuck, (you can see where it was stuck)but I freed the gears, looks like it got hot inside and carbon buildup ? The magnetic wheel that moves the spring to engage Needs cleaned and the gears need oil, but I do not have the right tools to push that wheel out it out.looks like a tiny snap ring. I would probably break it. I cleaned most of the soot out and will probably spray the whole thing out with some electrical cleaner and use a nosel and grease the gears .
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
Broke into the bottom end and cleaned most of the top end out. Looks pretty clean. The notorious wire doesn’t seem to be touching anything in the base,but there is no paper insulator. And the moisture drain filter/vacuum vent is crumbled away.
I searched everywhere and found the pdf for the ac/delco GM master cruise control manual. Finally found it. This is apparently a Canadian built unit, so I have to go get some maple syrup to lube those gears lol. Just joking my Canadian brothers….
I think I might get a lower cable and make sure everything works before yanking everything off.. I didn’t realize cables are super cheap still, well the old parts stores with the kindly gentleman behind the counter.
Getting late…. Save it for another day.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
I also picked up a 80” cable direct to directly hook up the speedo once the cruise control system is eliminated. Not sure if I need to get adjustment gear to fix the ratio. But will probably wait. I would like to get a taller stock width tire /rims
I haven’t even checked the vacuum brake release is working and the signal switch is missing, but I can just touch the two wires together to engage the switch by the brake pedal, then the servo…. I think it is cheaper to buy a newer universal cruise control kit for older vehicles than to rebuild a whole system…I am glad I never liked them lol
NLD79K10
Netherlands
Lars
You shouldn't need to change the gear ratio for the speedometer on the transmission as the ratio of the cruise control transducer is 1:1, you only need to change the driven gear if you run bigger tires (like I do) or change the gear ratio on your diff(s). There's plenty of choice in drive and driven gear for squares to get it as close as possible.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
@NLD79K10 thanks, yeah I currently have stock size tires P235 R 75 15
I figured I could safely go up a couple inches, but I thought the speedo would read a little low…. I think I got that right….losing my mind……. If you find it, please send it back.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
Crawled under the beast tonight to undo the lower speedo cable, darn that mounting bracket on the firewall was a bear to get broke free (9/16 nut). There was also a hold down with a tiny 3/8 nut, GM decided to put all the wires speedo etc on the same retainer. Glad I measured before ordering one, all the online stores recommended a 63” /64 1/2” with CC. The cable measured out to 56”. Took me a while to run down one, but found one on eBay…. Hurry up and wait time..lol
The gear ratio box adapter is in poor shape, but not sure what gears are in the rear end yet to compare to tire size,
I didn’t see a number on it. Not sure if it was changed out from stock?
Also ordered speedometer gear seal kit for the thm350.
NLD79K10
Netherlands
Lars
Just make sure that you don't put too tight curves in the speedo cable as it will certainly start to bind internally. I try to get nice large loops if I have to go over 90 degrees and keep an absolute minimum radius of 6 inch for bends up to 90 degrees.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
I just ordered the lower cable to the CC unit, It’s just a straight shot to the unit and from there straight shot to the speedo gauge. No bends to speak of. I ordered a 80” cable, so when I have time to remove the dash I will delete the CC all together. The 80” cable I test fitted and think I will need a couple of mounting clips on the inner fender well to keep the radius within working order.. I just need to grease up the cable really well. The cables are surprisingly really cheap at around $10-12.
It has been a slow moving process, Hell getting old……
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
I couldn’t find a replacement gasket for the CC unit lower and the filter, I winged it with some 40 year old gasket rubber sheets and an old scotch brite pad…..someone hand me the duct tape….
awar
K35
Be careful with the lube, it tends to migrate up the cable and really makes a mess inside a speedometer. Been there done that.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
Update: I removed the old speedo engagement fitting, purchased a new one with the hardware, side note. Be prepared to catch your tranny fluid lol. Had a oh **** moment lol…….I am not familiar with the Gear ratio box? It’s a Stewart Warner 666F x5 9444w. . I know. Mark of the beast…666F. Going to take it apart and see how it ticks….
Well , opened it up since it was pretty noisy/grinding. Looks like it is packed with wheel bearing grease. Pleasantly surprised by all metal gears…all the teeth are present/small amount of wear, going to clean it up regrease and slap it back on.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
Anyone have any recommendations on a mph phone app that you can use to judge how fast the speedo might be off? Figured I could get a close ratio……..
doo-daa
