Cruise control Delete
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
My 1978 GMC C15 has factory installed cruise control. The switch on the column is broke and the speedometer does not work.
I checked the unit in the engine compartment and it looks ok, but the vacuum lines are in really poor shape.
I want to simplify the speedometer situation by just running a new cable from a non-cruise control truck.(direct) Also want to clean things up for a different carburetor. (Edlebrock, Holley etc…)
I read that the vacuum also supplies power for the climate control doors inside the truck. (AC / Heat vents) Also the unit that is connected to the carburetor for the speed control.
I would like to just do a complete delete of the cruise control all together. Never liked using it anyway.
Has anyone ever done this in there truck? Is there a guide somewhere on rerouting the vacuum for the vent controls etc…
I didn’t get a great look at them tonight… the vacuum tee seems to be located near the distributor?
Any advice suggestions would be greatly appreciated, thanks
NLD79K10
Netherlands
Lars
My cruise control vacuum is capped off at the fitting at the intake manifold as a previous owner had already removed most of the cruise control system on my '79 K10 apart from the control unit itself but he decided to plug up the vacuum hoses instead of capping off the fitting. The HVAC system uses that same fitting for its vacuum as well but it takes its vacuum off a different port on that fitting. Just tracing the hose between the CC-unit and the vacuum fitting on the intake manifold will show you which port to cap off and you can then effectively dump the CC-unit and replace the two-part speedo cable with a single cable. This won't affect your HVAC controls other than potentially having less of a vacuum loss due to leaky CC vacuum hoses resulting in the control actuators working better.
I still haven't gotten round to removing the CC-unit and replace the speedo cable yet myself, and I am unlikely to replace that cable due to a Dakota Digital gauge set that will be put in place of the stock instruments.
ali_c20
Austria
Alexander
C20, K5
I removed my CC and use a single cable on my K5. The single cable totally sucks.
I tried all aftermarket direct replacement cables and all of them suck. I plan to put the CC unit back and use the 2 piece cable design. I don't know if that fixes anything but it can't get worse.
NLD79K10
Netherlands
Lars
@ali_c20 My K10 has bigger wheels than stock and the speedometer is so far off that it indicates my speed in knots rather than miles anyway, which is one of the main reasons I chose to put a DD gauge set in it in the first place.
ali_c20
Austria
Alexander
C20, K5
I run an adapter at the t case which works fine speed wise but the cables always bind or have slack or slip off the speedo clip or chirp.
Unfortunately the original cable which was fine and worked as it supposed to be melted on the exhaust.
DD unit is great but my K5 is registered as historic vehicle here in Austria and I can't switch to a DD gauge cluster.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
@ali_c20 I am interested in knowing what you mean by sucks, is it just the build quality of the product or something else? I would have thought a single cable would be no different?
Edit: After thinking about your comments, I wonder if you’re not having an angle issue? Just like the drive shaft in a curved shaft weed wacker. The cable in the shaft isn’t greased or has a kink will create a slap at the head end from the motor. This would cause a clicking noise at the speedometer?
I wonder if your aftermarket cable was not long enough and created a bend? Also did you use the factory mounting bolt on the back of the firewall that held the original two piece cable?
Any feedback is welcome, I do not want to run into undesirable issues.. thanks again.
75gmck25
Northern Virginia
Bruce
I replaced the cable on my ‘77 K25 (with NP203) a few years ago and it took some searching to find a cable with the correct end at the speedometer. The first one had a threaded connector (that won’t work) and the correct one has a metal bushing on the end that pushes in and is then held by a springy metal retainer on the back of the cluster.
I think this ATP Y816 is similar to the cable on my truck.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
@75gmck25 Yeah I thought about taking both my cables off and measuring both and add about 6 inches.. you know, For wiggle room, come on guys…….. lol
They list several different lengths, 80” 100” etc…. I didn’t think about the other end underneath… I will crawl under there and check. I figured I would not need to change the plastic gear in the tranny, but not familiar with the cruise control unit, wonder if it has some sort of gear ratio in the box? Other than the one in the tranny to regulate the speed showing on the Speedo. Everything is stock, except the stock motor has been rebuilt according to the previous owner.(just throwing that out there)
H2OnSnow
New Hampshire and Colorado
Rich
Blazer
Where is your module mounted? On my truck, if I added the two lengths and added 6 inches to that, the resulting cable would be about 2-3/4 miles too long. Use care.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
Yeah I bit the bullet to track down the problem, had some free time today. I removed the upper cable and it rotated fine. Put a drill to it in reverse and after a couple tries the speedometer started working….my drill on low speed was traveling at 30 miles an hour. Luckily within the speed limit. Lol.
I re-attatched the upper and removed the lower and noticed a piece of the cable snapped clean off inside the cruise control unit. I didn’t think anything of it before because it looked like a brand new square end. It protruded out , so it looks normal but in fact it is an inch too short. Not sure if the unit is frozen and that caused the cable to snapped clean but I am not going to by a new one. I might yank it off and see if you can take it apart tomorrow . Wish me luck.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
@H2OnSnow
Mine is located about half way down on the inner fender well on the drivers side
Also I was thinking the longer the cable the better, my train of thought was of less stress on the cable movement inside that casing if it was installed more of a u shape then with a tension of a shorter stock cable with a bend in towards the instrument panel.. there has to be a reason why some people are saying they have worn pieces at the speedometer location or hearing clicking and slap.. I almost entertained drilling another hole in the fire wall horizontal directly behind the cluster.. straight shot? Not sure that’s possible / not sure what is in the way,but this old mind has been turning…..it might be crazy idea….
I might do/try it after I remove the dash to replace it and replace the gauge cluster etc…
ali_c20
Austria
Alexander
C20, K5
The build quality. The angle to the tach straight in, no kinks or too small loop. I cleaned the cable and sheeting, lubed with graphite, tried all tricks that I could find.
The cables have more slack in the sheeting, the square parts of the cable that go into the tach and transmission/t case are thinner as on the OEM cable. The metal ends that screw / clip on are flimsy, thinner than the original. I think this all ads up to my tach issues. I plan to run a quality aftermarket cable to the CC unit and my original from CC to tach.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
@ali_c20 thanks for your reply. I also heard there were some really cheaply made cables. I was thinking of grabbing one from a reputable company and trying it out. I was thinking of using a high quality lithium grease used for weed wacker shafts. I rebuilt a few in my day and that echo red is amazing. Better than graphite in my opinion. That’s the plan anyways.. wish me luck.
awar
K35
I have had the mechanical cruise control unit seize and snap the cable. Most of the complaints about speedometer cables are on 4 wheel drive trucks like mine. I have a spare used OEM cable for my truck.
Since you have a 2 wheel drive truck I suggest that you purchase a replacement cable assembly for your truck without cruise control. The most difficult part of replacing the cable is under the dash and making the connection to the cluster itself. The housing doesn’t line up straight to the gauge and the release clip is a royal pain to operate. Start with the dash end when installing the new cable and housing. I remove the dash assembly to gain access to the cable. Disconnect the top cable from the cruise control unit so you can pull the cluster out away from the dash with the cable attached.
Be careful when routing the new cable, use the factory retaining clips if possible. Mine are steel and are bolted to places. This is important since speedometer cables and exhaust systems attract each other. They must love the heat. LOL.
DesertRat-NM
New Mexico
Norman
GMC C15
350c.i.
@awar Thanks, Yeah I have a lot to replace. I figured since I want to replace/repad the dash. I might as well pull the whole cluster and inspect all the wiring as well, vent tubes etc… As you said, It would be easier with all that taken apart. I am going to see if I can free up that unit, but still plan on removing it. I hate throwing a usable part in the trash, only if it’s not repairable.
79TanSquare
