Critique my build... Stump puller/Tow pig
82SquareBurb
Soddy Daisy TN
Derek
Do i need a basic oil pump or a high volume oil pump ?
Standard volume oil pump should be fine unless you plan to run larger bearing clearances (>.002") or a turbo.
Z28 Guy
mississippi
Jermaine
Okay. I been looking at oil pump pickup tubes ... which one do I need?
I didn't know it was so many choices...
xm20k
Girard, Ohio
Stock style works but I would tack weld it to the pump once you position it to be just off the bottom of the pan.
I prefer the style that bolts to one of the pump cover bolts, but you need to know the depth of the pan you're using, and they tend to be a lot more expensive but will never move around or fall out of the pump.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Measure the pan depth, and set your pump 1/4-3/8” from bottom of pan. Do what xm20k said,, weld it, do not skip this step. For a mostly stock build, I would use the stock pan.
doo-daa
