Z28 Guy
- Oct 7, 2022
- mississippi
- Jermaine
- C20
Last week i finally had a chance to pick up a 454ci block that was a hour drive away from me. Its a older block as the casting is a 3999289 block. Mark lV is what im thinking. Its a 2 bolt main deal. The stock peanut port 454ci just lacks towing power on the hills.
Right off bat im not trying to build a motor i have to work every 30 miles. I plan on using the motor/truck to tow my 4th gen camaro to Bowling Green yearly to LS fest which is a five hour road trip each way every september. Im really after a tow monster that can use any octane gasoline because lets be real here all Gas stations dont have good gas.
Here is what ive built so far on paper first before i buy anything else. What do you guys think or what would you change ?
~454ci block bored and stroked to 489ci
with Scat internals with forged pistons
~set compression around 9.3 or so...
~Cometic head gaskets
~Brodix 270 RR ovals
~Edelbrock Air gap intake
~ Erson 214/226 dur 550/550 lift 114 LSA camshaft
~ melling oil pump (basic)
~link bar lifters from Clay Smith
~Billet timing chain from CP
~long tube headers into a 2.5" H pipe setup with quiet mufflers but that flow well
The engine go live under 4000 RPM according to my math. Im running a 14 bolt, 4.10 gears, and a 29.5" tire.
Im leaning towards the Brodix heads for several different reasons. They are a true oval vs some competitors and they have the stock height exhaust port location.
