1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
'Crispy' 1989 R2500 Suburban
Discussion in '2wd Suburban, Blazer and Jimmy' started by BBBURB, Oct 23, 2019.
  1. BBBURB
    BBBURB Full Access Member
    64
    62
    Jun 26, 2019
    Anaheim, CA
    First Name:
    Zeke
    Truck Year:
    1989
    Truck Model:
    R2500 Suburban SLS
    Engine Size:
    454 7.4L
    I have here a Crispy Burb that came straight out of the Palm Springs CA. oven. Its a little cooked from our dessert sun. Paint peeling, dash cracked. Had to drive her 2 hours to get her home. The poor girl almost made it home but she passed out on the freeway only a couple miles from home. Tuned out to be p/owner had set the air cleaner housing right on the injector wire and it finally wore through shorting the system and blowing a few fuses. She was covered in rust. I actually wanted to keep the rusty patina but it was more work than i was willing to endure so I buffed out the rust with a sponge wheel then proceeded to rattle can the thing with some anti-rust primer layers and a couple layers of silver paint can. No more rust.
    This is my first build. She my daily driver now. I have a Harley and a new work van. But this is too much fun to drive and in California traffic people seem to just get out of the dam way for her. :whip: When i put on my left turn signal to merge I almost dont have to even look. People just disappear. :Whoa:
    I paid $1800 for her. Odometer is past mechanical limits. P/o said it has 105,000 but i seriously doubt that. Compression is between 120-140 psi. Came with new tires. Interior old but no tears. Carpet has significant stains (from sodas?).
    Im a little late starting my Under Construction thread here. I got her back in July 4 months ago. Here is her first picture after her bath and some brillo pad on the crusty parts. The roof had a ton of rust took me many hours to brillo :
    Old77 likes this.
  2. BBBURB
    64
    62
    Jun 26, 2019
    Anaheim, CA
    First Name:
    Zeke
    Truck Year:
    1989
    Truck Model:
    R2500 Suburban SLS
    Engine Size:
    454 7.4L
    Update after rattle can primer and paint and some new parts...
    New Parts List:
    ACDelco GF652 Professional Fuel Filter - Jul 12, 2019 - Amazon
    Delphi GN10048 Ignition Coil - Jul 5, 2019 - Amazon
    Accel Distributor Cap & Rotor - July 2019 - Autozone
    Front Disk Rotors - July 2019 - SpeedZone
    Front Brake Pads (Duralast Gold Semi-Metalic) - July 2019 - Autozone
    Monroe 34817 Gas-Magnum Truck Shock Absorber (Front x2) - Jul 21, 2019 - Amazon
    Monroe 34824 Gas-Magnum Truck Shock Absorber (Rear x2) - Aug 3, 2019 - Amazon
    Delphi PS10075 Manifold Absolute Pressure (MAP) Sensor - Jul 11, 2019 - Amazon
    Dorman 20771 PEDAL-UP! Brake Pedal Pad - Jul 30, 2019 - Amazon
    ACDelco 219-607 Professional Fuel Injection Throttle Body Rebuild Kit - July 2019 - Tops Auto Supply
    ACDelco 217-2281 Professional Throttle Body Fuel Injector (x2) - July 2019 - Tops Auto Supply
    Duralast Gold Wireset D801313 - July 2019 - Autozone
    Moog Sway Bar Bushing Kit - August 2019 - O'reilly Auto Parts
    2 x Dorman 38420 Door Striker Bolts - September 2019 - Amazon
    Upper Radiator Hose - September 2019 - O'reilly Auto Parts
    Lower Radiator Hose (Purchased But not Changed) - September 2019 - O'reilly Auto Parts
    Heater Hose x 2 - September 2019 - O'reilly Auto Parts
    Aluminum Thermostat Housing Neck & New Bolts - September 2019 - O'reilly Auto Parts
    TailGate Bolts - September 2019 - Summit Racing
    Duralast Gold Distributor Cap & Rotor (Lifetime Warranty) - October 2019- Autozone
    Mojave_Muse, Mr Clean and shanegtr like this.
Share This Page
