Shawn Wheeler
- Feb 10, 2019
- Arizona
- Shawn
- K10
Hello, asking for some words of wisdom.
1984 K10
Turn AC on at the dash like normal. The compressor does not turn on.
Check the fuse = Good
Supplied 12 volts from the batter to the compressor, I can hear the clutch engage when power is applied. It disengaged when power was removed.
I also put my test probe on the wire that connects to the compressor when the dash slider was set to AC. No light on the test problem.
And this is the end of my knowledge.
Where should look next?
And now for a stupid question. As a stop gap, can I direct wire a switch to the compressor?
Thank you in advance for your help.
1984 K10
