Adding my $.02, big filter can't hurt much of anything. I suspect that most filters are clogged up and start bypassing long before the oil is toast, but that is just me.
I started running the larger oil filter on my motorhome with the 8.1, and still changing conventional at about 3k miles, which is usually annual miles. For me, it was a simple decision since the factory system holds something like 9 quarts, and with the big filter, I can dump in (2) 5qt jugs and be done. It used to consume about 1 qt/thousand miles, and the low oil mark on the dipstick was about 3 qts low, so I never had to add really. After a lower temp thermostat, it looks like MUCH lower consumption, but it's so hard to track at the low driving rates I do. But the last couple oil changes I haven't noticed the dipstick low at all.
