- Aug 7, 2016
- Weiser Idaho
- Perry
- K20-K10
@CalSgt you really know how to diffuse the situation
same, it's peace of mind having a controller and 2 fans. One fails, it switches on the other.So many people here hate electric fans. Personally though, I like them. However, I very much prefer factory fans from a later model vehicle. Aftermarket fans are overrated.
With that said, the best place to put a single fan is anywhere within the core. There kinda needs to be a shroud though. And one that promotes flow through the core, not like some of the aftermarket ones that essentially make large areas of a radiator core a dead zone.
might be able to get the controller from an early 2000's chevy and put it to work with a few mods. 3 relay system so if one fails it switches to the other fan. Actually I think if 2 relays fails it will switch to one fan.....don't hold me to it....been a while since I looked at the schematic.I've always ran mine in pairs. One day I'll get fancy and have a temp sender for each fan, so one can come on later than the other, if needed. Still both with a manual override though.
Your an idiot.The easiest way is to improvise.
This setup is quick, easy, and doesn't even require any wiring! - When you drive, the fan automatically spins by itself!
Except the guy in the picture put the fan in BACKWARDS! It's not going to work like that - it will blow the air the wrong way!
With a shroud you pull air through the entire radiator. If against the fins you are only pulling air through the section covered by the fan.If the electric fan is against the radiator no shroud is required. Most aftermarket shrouds actually block tons of air flow. The fan motor itself blocks air flow. And past the effective speed of the fan,the fan blades themselves actually block air flow. If the fan can only pull air at a speed of 20 mph at 30mph they are blocking not pulling. Look at a good factory electric set up. A good factory setup will have a fan that is serious overkill,draws lots of amps and there are flaps in the shroud that open at road speed.
Is that why the vans were G series?sweet spot on a radiator?
G spot?
