Auto Locking Hubs?
Terlingueno
Fictional Western Sage
Far West Texas
Skeeter
K20 Suburban-SM465
Hey I have a 1984 K20 with werner auto locking hubs.
The description for 1980 sounds more like the setup I see where the washer with small holes that sits in the keyway of the spindle locks to a pin with the adjusting nut.
Should I follow the instructions for 1980? 160lbs just seems really high.
4. On 1980---84 K10---20/1500---2500 vehicles, proceed as follows:
a. On 1980 models, assemble adjusting nut lock by aligning nearest hole in lock with adjusting nut pin. Install outer locknut and torque to 80 ft. lbs.
b. On 1981---84 models, assemble drag sleeve retainer washer over the axle shaft and against bearing adjusting nut. The tang on the inside diameter of this washer is assembled in the keyway of the spindle. Assemble and tighten outer locknut to 160---205 ft. lbs.
Werner?
rydog
Lawrence KS
Si
The ones in the earlier post labeled Warn(er)
I think I'm just gonna go with my gut and go 80lbs. 160lbs is prolly why I had to use a impact to get them loose with that special socket
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
We are talking the outer nut, right?
rydog
Lawrence KS
Si
Yeah the outer one that goes up against the washer that falls into the spindle keyway that locks into the tab on the adjusting nut
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
In my years of working on these old rigs, DAMN tight was good enough.........probably close to 90-100 lbs
rydog
Lawrence KS
Si
Yeah that's about all I could do was 100 lbs with that special socket and a breaker bar
NateP350
