@gmbellew
OK, I zeroed the vacuum gauge and took another reading from the EGR port off the throttle body. Here’s what I got at idle in park and in drive. Looks to me like around 22” warm idle in park and around 19” warm idle in drive, idle fluctuating very slightly in drive at idle while testing which is one of those things I’m trying to clear up by going through everything.
Before taking these readings, I noticed that the PCV grommet was cracked so even after I caught the PCV halfway out and pushed it back in I still had a vacuum leak there. I replaced that. While I had the hose off the EGR port I sprayed some Berrymans TB cleaner through it and decided to spray it through the other ports as well. Found the Evap port completely plugged. I didn’t bother to check it back when I was going through the Evap system connecting everything back up. I should have. I notice a LOT less pressure behind the gas caps now. That may have been affecting the fuel pumps too. This morning I checked the o2 sensor wiring. The weatherpack connector is broken like every other connector has been. I had the exhaust shop replace the o2 and connect it since it was unhooked when I got it. They didn’t notice that it was completely full of dirt when they connected it to the new o2. I cleaned the connector and got it back on best I could, am going to replace that connector tomorrow, and then hook the laptop back up and see what I can see.
