Alaska; 86’ GMC Sierra Classic 1500 4x4 swb
BJedi76
Soldotna, Alaska
B.J.
GMC Sierra Classic 1500 4x4 SWB
305”
I have an ‘86 GMC Sierra Classic 1500, 4x4 swb. w/a 700r4 trans.
I don’t want a hot rod. I just want a smooth throttle & decent gas mileage.
The engine is an 80’ Canadian 350” out of a California 1ton van.
Carburetor is a 17066559 (M4MC I think)
I live at sea level, in Alaska, where the temperature ranges from 70° in the summer to -25° in the winter.
I am looking for a “heat stove & hot air intake air cleaner housing system.
...but my questions are:
- Do i need to tune it any different in winter vs summer?
- what rebuild parts (like jets etc) are appropriate for my drivetrain?
- Am i on the right track or is there a different way to go?
thanx...
Shorty81
Baby Boomer
North West ohio
Darren
Welcome from thousands of miles to the East.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
With all the original vacuum lines, thermal switches, heat stove, electric choke etc. installed, the engine should start and run fine at any temperature. Any parts that are missing or disconnected will effect cold start and or normal running temp.
That engine, I believe like my '82, has trapped vacuum spark for cold starts. Very important. Also would have locking converter defeat when cold. This also helps during engine warm up. The original carb was jetted very lean for fuel economy and emissions. A richer set of jets or other fuel mods will help for cold starts, but, fuel economy and emissions will suffer.
Do you still have a readable vacuum diagram sticker? The correct year factory service manual will have the diagram. The other question, is the carburetor the original '86, or is it from the 1980 donor?
75gmck25
Northern Virginia
Bruce
The heat stove and hot air intake connects the round port on the bottom of the air cleaner snorkel to a housing on the passenger side exhaust manifold. The housing on the manifold is just two pieces of shaped sheet metal riveted on, with a round hole in the top. There is a 2" metal hose that connects this heat stove to the port on the air cleaner snorkel.
In the air cleaner there is a temperature valve and it would be connected to engine vacuum and to the mechanism for a flapper that covers the port on the bottom of the air cleaner. When the engine starts there will be vacuum to the temp valve, which will pass through the vacuum and pull the flapper open (it is inside the snorkel and pivots up) so that hot air is drawn through the 2" pipe coming from the exhaust manifold. You are then drawing warmer air into the carburetor. As the engine temp increases the temp valve will cut off vacuum flow to the flapper and it will gradually move the flap down and start drawing air from the main snorkel.
Getting that hot air stove mechanism working should help cold weather operation, but working on the carburetor choke will probably be more effective. The round black cover on your choke should have index marks on the top and you loosen the 3 screws and rotate it left or right to lean or richen the choke.
Bruce
BJedi76
Soldotna, Alaska
B.J.
305”
thank you...
BJedi76
Soldotna, Alaska
B.J.
305”
I thought I was replying to a specific post. I guess this is a general reply to all posts.
Thank you for the “Trapped vacuum spark information” I was unaware of that. I was able to look that up.
but I was unable to find information on “ locking converter defeat“. what is that?
thank you...
BJedi76
Soldotna, Alaska
B.J.
305”
I have been unsuccessful in finding a complete heat stove, nor a working air cleaner housing.
I can find a new heat stove valve, But not the housing. I suppose that I will have to find a used one or fabricate one.
I found a few air cleaner housings, but none with a functioning hot air flapper.
Any parts sources for heat stove housing & functioning Air cleaner housing, would be appreciated.
thank you...
Turbo4whl
Downingtown, PA
Wayne
Jimmy
The converter lock has a tip in switch on the firewall that is the main control. At about 12 or 13 inches of vacuum the switch closes and current to the solenoid locks the converter. When the vacuum drops to about 8 inches the converter unlocks.
This system has two defeats. The vacuum is drawn from the manifold then runs through a thermal vacuum switch on the top of the intake manifold, or on the top of the engine thermostat cover. When the engine is very cold no vacuum passes through this thermal switch (valve).
The second defeat or shutoff is the electrical switch on the brake pedal.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
thank you...
This is common, the valve fails and the heat stove will not work. Get the housing with the bad operating valve. Using a chisel or drill remove the spot welds that are on the valve holding bracket. Install the new valve, then weld, screw or pop rivet the bracket back on.
BJedi76
Soldotna, Alaska
B.J.
305”
i assume that, when you speak of this “converter lock”, you mean, the transmission, when you use words like “solenoid” & “current”?
i wonder if this “locking converter defeat” thing, is why my truck lurches at stop signs or lights, when it’s still a little cold?
i’ve no idea what year my 700r4 transmission is. anyone know where i look to find out?
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Yes, I am referring to the transmission locking converter.
I am sure a heat stove air intake will help with the cold engine. You should continue looking for the parts needed to add this back on the engine. All these cold run items were needed to have a smooth transition from cold start to full engine temperature.
73c20jim
Tombstone, AZ
Sorry, can't help. It doesn't get cold in SE Arizona.
TubeTruck
East TN
Denis
Suburban K10
LQ9
So you're looking for al the stuff on my motor :Big Laugh: and yes, it all works. One of these days when I put EFI on it I'll sell it all.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Chevy Tom
Rhode Island
Thomas
my old truck with a properly tuned carb started fine in 90F or below 0. As long as the choke works fine it shouldn't need adjustment.
willyg
