AC Delete 83 C10
jcm66
florida
james
small block
got an old SBC not long ago, totally unfamiliar with cars so I figured fixing it up would be a good way to earn some mechanical ability. Anyways, im wanting to do an AC removal bc all I get is hot air anyway, so im getting an AC delete box that keeps the heater blower so I can still use defrost/heat.
My question is, after installing the box to the firewall, is there any thing that I need to do to the existing duct/venting or maybe something else on the cab side of the firewall? Or do I just need to slap the kit on there and call it good.
I’ve tried looking on YouTube for videos of people doing deletes and some take their whole dash apart and others seem like they just put the box on and that’s it. Any tips on the whole process would be greatly appreciated!!
awar
K35
If it is truly an a/c delete kit, it is probably all you need.
If it is just a non air underhood part you might want to replace the underdash parts with non air parts. You will have to patch the firewall if you go that way.
ali_c20
Austria
Alexander
C20, K5
I deleted the AC on my K5, just made a my own delete cover for the big square AC opening. I removed only the outer AC parts and kept the underdash parts. Put on the AC delete kit and that's it.
75gmck25
Northern Virginia
Bruce
Based on your questions, I don’t think you understand the system enough to start pulling things off. But maybe the A/C delete kit will give you all the info you need.
If you pull off the compressor and brackets, hoses, condenser and filter/dryer you have effectively deleted nearly all the A/C components. There is no need to remove the big box and the evaporator (in the box) under the hood unless you are trying to recover the space in the engine compartment. Just remove everything and don’t put the dash control in A/C mode. Everything else (blower, dash controls, etc.) will still work fine if vacuum is still connected to the controls and you have a good blower motor.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
I got to ask - why not fix the AC you have? No HP loss if you are not running it and it does not take up that much room. :think:
Best of luck with however you go.
NLD79K10
Netherlands
Lars
I got to ask - why not fix the AC you have? No HP loss if you are not running it and it does nottake up that muchroom. :think:
Umm, yeah, if I lived in Florida with my dislike of humid heat, I'd probably put a bit of effort and cash into having working AC just as a comfort item, but everyone is different.
For someone with little to no experience with automotive repair getting the AC back in the game would be a pretty good start too, as most of the stuff involved except for the evaporator is pretty accessible on the square. We don't know what is missing or broken on it though, so fixing it might be outside of budget or availability.
Johnny Atomic
Little Rock AR
Johnny
Sierra Classic 1500
You must not live in the south. A/C is a necessity not a luxury
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I did this on my K20 by buying a cheap full delete plate, and cutting it so it covered up the AC side of the firewall and left the blower motor uncovered.
Inside I just blocked the flap from going that direction, and let it blow heat to any outlet whenever the fan is on.
Everyone knows any place with a single temp over 80 ever was totally unpopulated until the invention of AC.
79TanSquare
